Civic Type-R Conversion
Old Feb 13, 2003 | 03:55 PM
OpTiX619's Avatar
Default Civic Type-R Conversion
I was wondering if anyone knows everything that is needed to convert a 96-00 civic hatch to Type-R. just for the parts that add performance from stock. not caring about interior and exterior because it will be a track car (H1). im just talking about performance wise. So far i know, we will need Engine which instead of the b16b, we will be going with ITR b18c5. and suspension, which will be rear disc conversion, etc. i searched thru hybridgarage and found some info about the motor. as far as i know i only need the 99-00 si rear mount and some wire harness mods. but for suspension it is kind of shady. I found a TypeR kit online but it is for Integra. I know they are similar but when it comes to type-r is it the same? and do i need to change anything else. Brakes & Suspension wise... we are just trying to get something to start with then go from there.
thanks for you input...
daniel
Old Feb 13, 2003 | 04:14 PM
EK MONEY's Avatar
Default Re: Civic Type-R Conversion (OpTiX619)
if your putting an ITR motor in it, and doin nothing inside and out, how is it a CTR?
Old Feb 13, 2003 | 04:18 PM
OpTiX619's Avatar
Default Re: Civic Type-R Conversion (Peagreenhatch)
its not going to be a real ctr. i mosty need to know information about suspension. its for performance... ctr parts bolt on.... 5 lug conversion, disc brakes in the back, etc...
mainly, we plan to combine the best of both worlds ITR, and CTR. But we are using the Hatch chasis for a reason... so to alter my question. which is the best way to go?
[Modified by OpTiX619, 1:21 AM 2/14/2003]
[Modified by OpTiX619, 1:24 AM 2/14/2003]
Old Feb 13, 2003 | 04:24 PM
AutomaticB16's Avatar
why don't you go with CTR???? In my opinion The Civic Type R cams are better then Integras.
Old Feb 13, 2003 | 04:25 PM
OpTiX619's Avatar
Default Re: Civic Type-R Conversion (AutomaticB16)
because we will be competing with ITR's.
Old Feb 13, 2003 | 04:29 PM
My car beats Integra Type r (well lost against 2 of them) and i only have civic type r piston over bored and knife edge crank and civic type r cams. but its cool, do whats best for you
OpTiX619's Avatar
we dont plan on racing in straight lines here...
Old Feb 13, 2003 | 04:31 PM
are you doing like rally track type thing??
Old Feb 13, 2003 | 04:34 PM
OpTiX619's Avatar
Track Racing. YES! mmmm.. HONDA CHALLENGE....
Old Feb 13, 2003 | 04:36 PM
well ****, why didn't you say so. About that topic, i couldn't really help you. just beef up your suspension like crazy!!! Use redline oil that **** is good! (but mobil one is the best ****) redline gives more power and better response
Old Feb 13, 2003 | 04:39 PM
OpTiX619's Avatar
yea. that is one of the reasons we will be doing the Type-R Suspension conversion. but im still wondering what all needs to be swapped out...
Old Feb 13, 2003 | 04:41 PM
Finest's Avatar
If you're going track racing, I would highly suggest you read up on the rules and regulations concerning your class. Then you can go about extracting HP out of it.
i think i can get you a brand new 0 miles integra type r motor. but i don't know if it comes with all the ecu,axles,andtranny. but the motor has 0 miles. i think for 4500 bucks. if you are intrest in it let me know
Old Feb 13, 2003 | 04:45 PM
OpTiX619's Avatar
Default Re: Civic Type-R Conversion (98CTRCoupe)
to bad they did not come out with the USDM CTR... so with the type R motor we will be jumping directly into H1 class so from there we can pretty much do anything. it does however need to stay N/A so no turbos, etc... with track its H1-H4. H4 being pretty much bone stock off the showroom floor...
Old Feb 13, 2003 | 04:46 PM
OpTiX619's Avatar
if you could email your info about the motor we may be interested.... ioptix619@yahoo
Old Feb 13, 2003 | 04:47 PM
JoeB16.
Guest
Posts: n/a
Gay Pride
Old Feb 13, 2003 | 04:54 PM
Default Re: Civic Type-R Conversion (JoeB16.)
check your mail
Old Feb 13, 2003 | 04:59 PM
OpTiX619's Avatar
heh, HO SIC LA
Old Feb 13, 2003 | 05:02 PM
now you have mail. i forgot to add the .com part on the mail
Si_Guy2000
Suspension & Brakes
12
Jan 7, 2006 12:24 PM
enviousdm
Oct 6, 2005 04:48 PM
Phase2
Aug 29, 2003 07:16 AM
