some new suspension products i had in mind
how useful do you guys think things like these are for handling? launching?
I would assume this one mounts between the control arms similar to how the DC rear lower tie bar mounts but this unit looks stronger since theres no moving parts
I think this is the one for the Integra
Theyre only $95 each and if they actually provide some stifness it wouldo be worth it to me
they'd probably help with launching but, as for actual handling, they'd probably make your car push like no other...
if you're going to stiffen up the front like that, you'd definitely want to do something similar in the back to cancel out some of the understeer that this thing would create.
-tony
-tony
since the image is hosted by JIC im guessing they make it.
im working on my suspension setup after my turbo setup is completed... koni struts with my GC coil overs... i have front and rear upper strut bars but was lookin for soemthing else... i am looking at that bar and thinking it'll help a bunch and now i guess i just added a mugen 24mm rear sway bar to the list
since i have an LS, what kind of mods to the subframe will i need to make so that this bar works and doesn't tear it up?
or should i just stick with my strut bars, get an itr rear sway bar and call it a day?
the big one in the pic isnt off an Integra but i got those pics of the JIC Magic website
geez 24mm rear bar, i hope they include a serious mounting kit with that or youre gonna tear your subframe to pieces
does anyone know the sizes of the ST bars?
how to safely stiffen the living ***** out of the rear without tearing my subframe to pieces
do they make rear traction bars like that?
yeah i've seen the JIC website before
I thought maybe these were different...
I don't think they make the multi point one for the Integra...only the two point one.
i thought the Mugen was 26mm.
Mugen also makes 22mm front for the gsr and 22mm,24mm,and26mm front for ITR.[Modified by M-Type, 12:42 AM 2/15/2003]
well i just got a full set of ST bars for 102 plus shipping so i consider that a steal and ill be running those, gotta be a lot better than stock still and when i get the springs and dampers ill be all set
Natural Aspirations
Suspension & Brakes
19
May 31, 2008 08:26 AM
