88 si trnas. in a 91 si
I have this setup in one of my 91's. Best way to go is get a 212mm disk from ACT that has the 88 spline pattern. You don't want to use the shitty 190mm 88 disk.
just order a disc for a 86-89 accord 2.0 and it will fit on the 88 tranny's and its a 212mm disc.. just use the 90-91 pp and flywheel, that is all that the "88 upgrade" is from act.... this has been talked about tons of times do a search and alot of info wll come up..
