A $40 Home Dyno ?
I found a site that sell a program that you can make a homeade dyno all you need is their program a timing light and a sound recorder and of course a pc
I'm thinking about buying it but I wanna know if its really worth it
here is the site http://www.charm.net/~mchaney/homedyno/dynokit.htm
thanks
thanks
....maybe i just don't know anything, but how can you tell how much power you have by sound of your car???
if thats true we should ask blind people to just tell us how much power we make
If you know your gear ratios, and the overall OD of your tires, vehicle wieght, and the drag coefficient of your vehicle, then you can estimate horsepower by reading RPM. The mic just reads RPM. It does work, if you can manage to use it correctly.
i'll have to find that page again....i'll post it if i do...
i actually saw a dyno that you have to remove your drive wheels for and it attached to the hubs
apparently this system is more accurate since it takes the movement directly from the hub rather than being skewed by tires
click here: dynapackusa.com
a pic from the site:
Yeah, but how often do you drive on your hubs? If you are doing that you might as well pull the engine and test the HP at the Flywheel. WHP is what counts.
ask TimoneX about the home dyno, i remember he used it to tune his crower cams about a year or two ago
the main thing that you would use a dyno for is tuning, that lacks a wide ban 02 - I think its just a waist of money
