Need Help
I am not sure what size plug you will need, i have one on my car i got from lowes, cost like 50cents to a buck for 2 of them. First take the wiper off, i am not sure how your is cause mine was gone when i got the car, either way. There should be a big *** nut around the thing that attaches to the arm to wipe, then you should be done with the top, it is very simple to do this, just make sure you have the plug first. Now down to the underside of the hatch. You do not need to remove the hole panel, i did it without. If i can remember, i think there may have been a few screws that held on the back piece, pull on it and there will be some clips carefull not to pull to hard so you do not break\bend your panel or clips. You will then see 3 or 4 bolts attached to the wiper motor holdign it on, take those out, unplug the harness, pull it out, there you go, plug the hole and that is it. Very easy i did it in like 10 minutes or less.
ep3man
Sep 14, 2008 12:07 PM
