TPS woes part 2
Old Feb 13, 2003 | 08:09 AM
EF_LSVtec's Avatar
Default TPS woes part 2
Anyone here had TPS problems using aftermarket TB? I replaced my TB with a BBK 70mm and then switched to Ericks Racing 66mm, also replaced with new TPS sensor, calibrated...still getting a code. I wonder if I should rewire directly from the TPS to the ECU, maybe a loose connection somewhere. Input please.
Old Feb 13, 2003 | 08:55 AM
model x's Avatar
Default Re: TPS woes part 2 (EF_LSVtec)
When I first installed my b16 I installed the TPS incorrectly. I didn't line up the TB taps to fit into the TPS slots and that gave me a code. Try takin off the TPS but keep it plugged in, then reset the ecu and start the car to see if you still get a code.
Old Feb 13, 2003 | 09:40 AM
EF_LSVtec's Avatar
Default Re: TPS woes part 2 (model x)
i'll try that tonight, thanks
andyc_0652
Nov 18, 2010 06:54 PM
bam_89
Dec 10, 2009 09:44 PM
Devious951
Sep 18, 2009 05:11 PM
soulassasincc
Apr 9, 2006 11:16 PM
psegs80
Jul 15, 2005 05:07 AM
