h22 or b18c1
Old Feb 13, 2003 | 03:56 AM
Prof. Crumb's Avatar
Default h22 or b18c1
Modified by sneaky R at 8:57 PM 8/22/2004
Old Feb 13, 2003 | 05:31 AM
BeerBaron105's Avatar
Default Re: h22 or b18c1 (str8 hybrd)
well let me clear somethinjgs up for u
the handling thing about the h22 is a complete joke
yes if u use it in auto x u will notice a difference over a b18 powered car
daily driving the beast is no prob, the two guys i know with h22s ive driven with them, and as long as u are aware of the potential power, then u can easily city drive
if u enjoy straight line performance, an h22 would pump a b18 like there is no tommorrow, h22 mid 13s , b18c1 low-mid 14s
Old Feb 13, 2003 | 05:35 AM
White Lightnin's Avatar
Default Re: h22 or b18c1 (BeerBaron105)
Kind of wish I had gone h22 instead. Oh well, Im going FI in the fall.
Old Feb 13, 2003 | 05:41 AM
Noe Kozz's Avatar
Default Re: h22 or b18c1 (White Lightnin)
Both the H22 and B18 are good platforms. You just need to complement your suspension to match the H22 a little more. I for myself still can't decide, but that's no problem since I'm still in the process of saving up $$$$.
Old Feb 13, 2003 | 05:43 AM
Nikos's Avatar
Here's something I picked up from Honda-tuning
Please comment:
Interestingly, what you won't find under the hood of any of those dragsters is an H series engine. Despite apparent built-in advantages--such as a closed deck from the factory and a bigger bore and stroke--chief Holeshot wrencher Aaron Bonk tells us that the H is rarely used in drag engines. Part of the reason is the way the cylinders are lined. The sleeves in the H are much thinner, which don't allow for the flexibility in boring that one can take advantage of with a race-prepped B series engine. Because of this, the cylinder walls can't take the ultra-high boost levels found in modern front-wheel drive dragsters. Bonk points out that while an H engine can comfortably produce between 600 and 700 hp, there are B engines that are putting out close to 1000. Luckily, for our street-driven Civic, such high-horsepower concerns are irrelevant, however interesting they may be.
length
Mar 18, 2003 07:44 AM
