Very Informative ish! Greddy/Int. gate peeps, read up!
Old Feb 12, 2003 | 10:48 PM
JalopySiR's Avatar
Default Very Informative ish! Greddy/Int. gate peeps, read up!
Some of you may know what I am up to with my turbo project. Anyways, here is the best technical explanation of it I have found. It is a long read but it is very informative. I will highlight the important ish and throw in some pics. Greddy people, read up!
The following excerpts are from Jay Kavanaugh, a turbosystems engineer at Garret, responding to a thread on http://www.impreza.net regarding exhaust design and exhaust theory:
“Howdy,
This thread was brought to my attention by a friend of mine in hopes of shedding some light on the issue of exhaust size selection for turbocharged vehicles. Most of the facts have been covered already. FWIW I'm an turbocharger development engineer for Garrett Engine Boosting Systems.
N/A cars: As most of you know, the design of turbo exhaust systems runs counter to exhaust design for n/a vehicles. N/A cars utilize exhaust velocity (not backpressure) in the collector to aid in scavenging other cylinders during the blowdown process. It just so happens that to get the appropriate velocity, you have to squeeze down the diameter of the discharge of the collector (aka the exhaust), which also induces backpressure. The backpressure is an undesirable byproduct of the desire to have a certain degree of exhaust velocity. Go too big, and you lose velocity and its associated beneficial scavenging effect. Too small and the backpressure skyrockets, more than offsetting any gain made by scavenging. There is a happy medium here.
For turbo cars, you throw all that out the window. You want the exhaust velocity to be high upstream of the turbine (i.e. in the header). You'll notice that primaries of turbo headers are smaller diameter than those of an n/a car of two-thirds the horsepower. The idea is to get the exhaust velocity up quickly, to get the turbo spooling as early as possible. Here, getting the boost up early is a much more effective way to torque than playing with tuned primary lengths and scavenging. The scavenging effects are small compared to what you'd get if you just got boost sooner instead. You have a turbo; you want boost. Just don't go so small on the header's primary diameter that you choke off the high end.
Downstream of the turbine (aka the turboback exhaust), you want the least backpressure possible. No ifs, ands, or buts. Stick a Hoover on the tailpipe if you can. The general rule of "larger is better" (to the point of diminishing returns) of turboback exhausts is valid. Here, the idea is to minimize the pressure downstream of the turbine in order to make the most effective use of the pressure that is being generated upstream of the turbine. Remember, a turbine operates via a pressure ratio. For a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. This means the turbine is able to do the most amount of work possible (i.e. drive the compressor and make boost) with the available inlet pressure.
Again, less pressure downstream of the turbine is goodness. This approach minimizes the time-to-boost (maximizes boost response) and will improve engine VE throughout the rev range.
As for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side.”
"As for the geometry of the exhaust at the turbine discharge, the most optimal configuration would be a gradual increase in diameter from the turbine's exducer to the desired exhaust diameter-- via a straight conical diffuser of 7-12° included angle (to minimize flow separation and skin friction losses) mounted right at the turbine discharge. Many turbochargers found in diesels have this diffuser section cast right into the turbine housing. A hyperbolic increase in diameter (like a trumpet snorkus) is theoretically ideal but I've never seen one in use (and doubt it would be measurably superior to a straight diffuser). The wastegate flow would be via a completely divorced (separated from the main turbine discharge flow) dumptube. Due the realities of packaging, cost, and emissions compliance this config is rarely possible on street cars. You will, however, see this type of layout on dedicated race vehicles.
A large "bellmouth" config which combines the turbine discharge and wastegate flow (without a divider between the two) is certainly better than the compromised stock routing, but not as effective as the above.
If an integrated exhaust (non-divorced wastegate flow) is required, keep the wastegate flow separate from the main turbine discharge flow for ~12-18" before reintroducing it. This will minimize the impact on turbine efficiency-- the introduction of the wastegate flow disrupts the flow field of the main turbine discharge flow.
Necking the exhaust down to a suboptimal diameter is never a good idea, but if it is necessary, doing it further downstream is better than doing it close to the turbine discharge since it will minimize the exhaust's contribution to backpressure. Better yet: don't neck down the exhaust at all.
Also, the temperature of the exhaust coming out of a cat is higher than the inlet temperature, due to the exothermic oxidation of unburned hydrocarbons in the cat. So the total heat loss (and density increase) of the gases as it travels down the exhaust is not as prominent as it seems.
Another thing to keep in mind is that cylinder scavenging takes place where the flows from separate cylinders merge (i.e. in the collector). There is no such thing as cylinder scavenging downstream of the turbine, and hence, no reason to desire high exhaust velocity here. You will only introduce unwanted backpressure.
Other things you can do (in addition to choosing an appropriate diameter) to minimize exhaust backpressure in a turboback exhaust are: avoid crush-bent tubes (use mandrel bends); avoid tight-radius turns (keep it as straight as possible); avoid step changes in diameter; avoid "cheated" radii (cuts that are non-perpendicular); use a high flow cat; use a straight-thru perforated core muffler... etc.”
"Comparing the two bellmouth designs, I've never seen either one so I can only speculate. But based on your description, and assuming neither of them have a divider wall/tongue between the turbine discharge and wg dump, I'd venture that you'd be hard pressed to measure a difference between the two. The more gradual taper intuitively appears more desirable, but it's likely that it's beyond the point of diminishing returns. Either one sounds like it will improve the wastegate's discharge coefficient over the stock config, which will constitute the single biggest difference. This will allow more control over boost creep. Neither is as optimal as the divorced wastegate flow arrangement, however.
There's more to it, though-- if a larger bellmouth is excessively large right at the turbine discharge (a large step diameter increase), there will be an unrecoverable dump loss that will contribute to backpressure. This is why a gradual increase in diameter, like the conical diffuser mentioned earlier, is desirable at the turbine discharge.
As for primary lengths on turbo headers, it is advantageous to use equal-length primaries to time the arrival of the pulses at the turbine equally and to keep cylinder reversion balanced across all cylinders. This will improve boost response and the engine's VE. Equal-length is often difficult to achieve due to tight packaging, fabrication difficulty, and the desire to have runners of the shortest possible length.”
"Here's a worked example (simplified) of how larger exhausts help turbo cars:
Say you have a turbo operating at a turbine pressure ratio (aka expansion ratio) of 1.8:1. You have a small turboback exhaust that contributes, say, 10 psig backpressure at the turbine discharge at redline. The total backpressure seen by the engine (upstream of the turbine) in this case is:
(14.5 +10)*1.8 = 44.1 psia = 29.6 psig total backpressure
So here, the turbine contributed 19.6 psig of backpressure to the total.
Now you slap on a proper low-backpressure, big turboback exhaust. Same turbo, same boost, etc. You measure 3 psig backpressure at the turbine discharge. In this case the engine sees just 17 psig total backpressure! And the turbine's contribution to the total backpressure is reduced to 14 psig (note: this is 5.6 psig lower than its contribution in the "small turboback" case).
So in the end, the engine saw a reduction in backpressure of 12.6 psig when you swapped turbobacks in this example. This reduction in backpressure is where all the engine's VE gains come from.
This is why larger exhausts make such big gains on nearly all stock turbo cars-- the turbine compounds the downstream backpressure via its expansion ratio. This is also why bigger turbos make more power at a given boost level-- they improve engine VE by operating at lower turbine expansion ratios for a given boost level.
As you can see, the backpressure penalty of running a too-small exhaust (like 2.5" for 350 hp) will vary depending on the match. At a given power level, a smaller turbo will generally be operating at a higher turbine pressure ratio and so will actually make the engine more sensitive to the backpressure downstream of the turbine than a larger turbine/turbo would. As for output temperatures, I'm not sure I understand the question. Are you referring to compressor outlet temperatures?
The advantage to the bellmouth setup from the wg's perspective is that it allows a less torturous path for the bypassed gases to escape. This makes it more effective in bypassing gases for a given pressure differential and wg valve position. Think of it as improving the VE of the wastegate. If you have a very compromised wg discharge routing, under some conditions the wg may not be able bypass enough flow to control boost, even when wide open. So the gases go through the turbine instead of the wg, and boost creeps up.
The downside to a bellmouth is that the wg flow still dumps right into the turbine discharge. A divider wall would be beneficial here. And, as mentioned earlier, if you go too big on the bellmouth and the turbine discharge flow sees a rapid area change (regardless of whether the wg flow is being introduced there or not), you will incur a backpressure penalty right at the site of the step. This is why you want gradual area changes in your exhaust."
Well, that was fun, huh? Here is a pic of what I will be doing.
Old Feb 12, 2003 | 11:12 PM
Daniel's Avatar
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (JalopySiR)
bad ***
Old Feb 12, 2003 | 11:22 PM
Full-Race Javier's Avatar
hmm, does this mean equal length manis and properly designed collectors work?
Old Feb 12, 2003 | 11:39 PM
Full-Race Geoff's Avatar
i like merge collectors. superT check this out...
Old Feb 13, 2003 | 12:23 AM
Stu's Avatar
Stu
New User
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (FFgeoff)
I learned a lot from this, thanks for posting it. Although I also learned that what I was thinking before was not entirely wrong.
Old Feb 13, 2003 | 01:13 AM
pissedoffsol's Avatar
25 Year Member
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (Stu)
good info
one question- what is VE?
Old Feb 13, 2003 | 02:40 AM
UberTeg's Avatar
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (delvtecsol)
good info
volumetric efficiency
Old Feb 13, 2003 | 02:54 AM
25 Year Member
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (UberTeg)
thats what i thought- just wanted to make sure. thanks!
Old Feb 13, 2003 | 04:48 AM
SiRkid's Avatar
good stuff
Old Feb 13, 2003 | 07:53 AM
JalopySiR's Avatar
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (SiRkid)
This is basically why the Greddy kits and most stock turbocharged vehicles spike when upgrading exhaust. The first thing that needs to be upgraded is the poorly designed cast turbine discharge thingamabob. This item is completely contarary to everything said above. Very large size necking down to a small outlet. The flange must be changed for maximum power to be realized, and prevent boost irregularities.
Old Feb 13, 2003 | 08:16 AM
paulzy's Avatar
hummm...even Garrett agrees huh?
What I mean is that innovative swears that a full 3" downpipe will hurt performance more than a 2.5"into 3"....They reason is that teh discharge opening is only 2.5" at largest for most turbos used. THe full 3" downpipe will cause turbulence and backpressure around the discharge area
anybody agree with what Innovative says? I totally agree
Old Feb 13, 2003 | 08:21 AM
Aeka GSR's Avatar
New User
so do we just need to make this kind of downpipe or do we also need to make modifications to the turbine?
Old Feb 13, 2003 | 08:41 AM
MachAF's Avatar
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (Paul_Vang)
3 inch could cause backpressure, it depends on total exhaust flow. When you decrease the size of the pipe the air flow through it will increase in velocity in lower the pressure. In a larger size pipe the air flow velocity if decrease and the pressure will increase.
3inch pipe couldbe better than 2.5", it all depends on how much air will be flowing through it. As the guy from garret said, 250hp 2.5 is good, 300+ 3 inch better.
Old Feb 13, 2003 | 09:02 AM
DeepSi's Avatar
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (machaf)
I think I am going to have to reread this a couple of times tofully understand it. But excellent info, nice job
Old Feb 13, 2003 | 11:28 AM
WA  DA  TA's Avatar
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (DeepSi)
Excellent reading... thanks
Old Feb 13, 2003 | 11:30 AM
camp1320.com's Avatar
same here
Old Feb 13, 2003 | 12:38 PM
Paul -- While a 2.5" flare/trumpet horn to a 3" would often work very well, you are forgetting the limited amount of space there is to work with.
On my personal car, i chose to use a V band on a t3 turbo. becuase of this, if i wanted to bring the downpipe out any farther it would hit the radiator. I assure you, the changes from using a 2.5" flare cone, immediately going to a 3" would be negligable.
One intersting thing -- i jsut did a lab in school today which basically used a centrifigal compressor and we used a 10 foot long tube attached to the inlet with an ASME horn. It was interesting to monitor how fully developed the flow is at various points in the tube.
This is one of the best reasons why a long runner and a merge collector work well together. The flow leaving the exhaust ports is very excited and turbulent, and it takes at least the length of a fairly long runner for that flow to settle to laminar.
Old Feb 13, 2003 | 01:52 PM
Speedworks801's Avatar
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (camp1320.com)
Interesting.
Old Feb 13, 2003 | 02:07 PM
falcongsr's Avatar
What is this crap?
excellent read
i wish i could separate the WG port from the turbine discharge on my greddy like your pic does, but i couldnt retain AC with that.
Old Feb 13, 2003 | 05:02 PM
FredoSP's Avatar
awesome post!!!
Old Feb 13, 2003 | 05:26 PM
Loco Honkey's Avatar
I know it's crude, but I was in a hurry... Anyway, I beat ya to it...
Old Feb 13, 2003 | 08:25 PM
JalopySiR's Avatar
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (Loco Honkey)
Unfortunately, I really can't see what you got going on there, but I think I get the idea. This idea isn't new. I have just yet to see it on a honda with a non-divorced discharge turbine. It is very common on JDM Nissans. It is ridiculously easy on a DSM or internally gated T3, as they have the divorced housings and the discharge flanges come with 2 holes. Correct me if I am wrong, but that is an internal gate T3 you are using, right? Anyway, this post is mostly for the Greddy heads and the handful of us who use real T-25 turbos... These people must build a custom flange with a "tongue" that inserts into the housing to divide the two flows. Any machinist type shops wanna step up and do a buy on a flange/dp like the unit pictured?
Old Feb 13, 2003 | 08:45 PM
paulzy's Avatar
beautiful bowtie
Old Feb 13, 2003 | 11:00 PM
like this T25 flange? i wanted to weld a tongue to separate the flows, but warping of the flange and not being able to surface it discouraged me.
[Modified by javierb14, 12:01 AM 2/14/2003]
Old Feb 13, 2003 | 11:14 PM
JalopySiR's Avatar
Default Re: Very Informative ish! Greddy/Int. gate peeps, read up! (javierb14)
Yes, b-zactly like dat. Although, I will be using an open atmosphere dump. Just curious, wherefrom is that DP/flange found?
