I need a cheap suspension setup, any ideas?
Old Feb 12, 2003 | 09:37 PM
(__________)'s Avatar
Default I need a cheap suspension setup, any ideas?
I just picked up a 92 dx hatch and i want some different suspension cause whats on it now blows. Im not looking to spend alot since it is a daily driver.
I was thinking of some sprint or suspension technique springs with some kyb gen 2 struts. Does this sound like a nice cheap setup or is there any other shocks that are pretty cheap and are good?
Old Feb 12, 2003 | 09:45 PM
Mike36's Avatar
Default Re: I need a cheap suspension setup, any ideas? (steves98itr247)
Great way to tighten up around the corners for under 50 bucks with oem parts is a gsr or si stock sway and a gsr crossmember (the bar under behind the engine). cant go wrong with oem.
Old Feb 12, 2003 | 09:53 PM
tominos's Avatar
i've been searching the archives for info about shocks lately, and it seems that kyb agx is the best inexpensive shock to go with. also adjustable. as for the kyb gr2, some have had luck with them on lowering springs, but they are not a true performance shock, just a oem replacement shock. you probably don't want to rip your suspension apart twice to replace the blown shocks, so kyb agx is the way to go. i just bid on some on ebay.
Old Feb 12, 2003 | 09:59 PM
Soulless's Avatar
Default Re: I need a cheap suspension setup, any ideas? (tominos)
Ive been looking for some shocks, and i have filled it down to KYB AGX or Koni yellows....its all depends on what you want and how much money you have.
Old Feb 12, 2003 | 10:00 PM
ELUD THS's Avatar
New User
Default Re: I need a cheap suspension setup, any ideas? (Soulless)
i juts put my agx;s on a few days ago, so far so good for the price
jakop92
Suspension & Brakes
Oct 28, 2010 10:35 PM
2Accords
Mar 21, 2009 03:40 PM
el_huevoEK2099
Feb 16, 2009 09:22 PM
s2k_3.11
Feb 22, 2007 08:10 PM
jlh22179tx
Suspension & Brakes
Sep 28, 2006 09:01 AM
