I need a cheap suspension setup, any ideas?
I just picked up a 92 dx hatch and i want some different suspension cause whats on it now blows. Im not looking to spend alot since it is a daily driver.
I was thinking of some sprint or suspension technique springs with some kyb gen 2 struts. Does this sound like a nice cheap setup or is there any other shocks that are pretty cheap and are good?
Re: I need a cheap suspension setup, any ideas? (steves98itr247)
Great way to tighten up around the corners for under 50 bucks with oem parts is a gsr or si stock sway and a gsr crossmember (the bar under behind the engine). cant go wrong with oem.
i've been searching the archives for info about shocks lately, and it seems that kyb agx is the best inexpensive shock to go with. also adjustable. as for the kyb gr2, some have had luck with them on lowering springs, but they are not a true performance shock, just a oem replacement shock. you probably don't want to rip your suspension apart twice to replace the blown shocks, so kyb agx is the way to go. i just bid on some on ebay.
Re: I need a cheap suspension setup, any ideas? (tominos)
Ive been looking for some shocks, and i have filled it down to KYB AGX or Koni yellows....its all depends on what you want and how much money you have.
