Damn, I knew i shouldnt have tried to install my vtec controller
Old Feb 12, 2003 | 09:19 PM
3gLudeH22A's Avatar
Default Damn, I knew i shouldnt have tried to install my vtec controller
This shiot is hard as hell!!! Ive pretty much messed up my ecu adapter harness. The worst part is trying to tie all the wires together....Hmmm maybe i should have used butt connectors instead of the connectors that are supplied...Is that a better idea anyway??? But id rather go through this than pay my local shop 400 bucks. for me
Old Feb 12, 2003 | 09:40 PM
Que_Lude's Avatar
Default Re: Damn, I knew i shouldnt have tried to install my vtec controller (3gLudeH22A)
Cut off all of those stupid connectors that came with the unit. Solder all of the connections for the best connection. Some people use those metal crimp tubes and get them to work fine. Use heat shrink wrap over the connected wires.
Old Feb 12, 2003 | 10:11 PM
Que_Lude's Avatar
Old Feb 13, 2003 | 12:33 AM
j70wn's Avatar
that's ok ... just take your time and you'll get the hang of soldering. Did you try doing it on some test wires prior?
Old Feb 13, 2003 | 05:26 AM
RAB's Avatar
RAB
Default Re: Damn, I knew i shouldnt have tried to install my vtec controller (j70wn)
Hahaha that's funny you fucked up.
Old Feb 13, 2003 | 07:05 AM
TurboLude97's Avatar
all you have to do is make sure you heat the wire up.. put a little solder on the tip, place on wire, and touch solder to opposite side of wire. This makes sure you don't have a cold solder joint (which tend to brake or make sucky contact). Not much to it.
argh, ok i forgot to log out of my brother's name again.. once again it's rjr162
[Modified by TurboLude97, 11:05 AM 2/13/2003]
Old Feb 13, 2003 | 08:40 AM
LordVtec's Avatar
Default Re: Damn, I knew i shouldnt have tried to install my vtec controller (RY8127)
and to think this all could have been avoided if you would have asked or performed a search... there have been several informative post that basically make the installation idiot proof... i posted one a couple months ago with diagrams and all.. good luck.
Old Feb 13, 2003 | 09:21 AM
3gLudeH22A's Avatar
Default Re: Damn, I knew i shouldnt have tried to install my vtec controller (LordVtec)
I did do a search...and yes a found tons of info....Its just this is my first time doin this.
UPDATE: I finally got it wired up and plugged in....Now im getting a vtec solenoid CEL...and the damn controller wont even power on.
Old Feb 13, 2003 | 09:47 AM
MugenPoweredLude's Avatar
[QUOTEBut id rather go through this than pay my local shop 400 bucks. for me[/QUOTE]
Thats crazy...my shop is going to charge me $250 for install and dyno tuning....but of course i dont have the money
Old Feb 13, 2003 | 11:14 AM
swrdply400mrelay's Avatar
Did you ground it?
Old Feb 13, 2003 | 11:58 AM
3gLudeH22A's Avatar
Default Re: Damn, I knew i shouldnt have tried to install my vtec controller (swrdply400mrelay)
UPDATE 2: Right before my ride to work showed up, i looked over the wiring again....I HOOKED ONE OF THE GROUND WIRES TO THE WRONG WIRE!! So when i get off work i will see how it goes.
Another round of for me
Old Feb 13, 2003 | 12:01 PM
Boostless97Lude
Guest
Posts: n/a
it's all good man, that's the hardest part of having a hybrid..... nothing is simple, but i commend you for trying so hard, and to you
Old Feb 13, 2003 | 12:09 PM
Crate's Avatar
Default .
PLEASE dont just twist them and tape them.
the vafc is highly sensitive to ressistance. a good solid connection is very important.
Old Feb 13, 2003 | 07:31 PM
3gLudeH22A's Avatar
Default Re: . (Crate)
Well i finally got the wires goin to the right places when i got home today. It wasnt as bad as i thought...Just frustrating when you attempt it the first time. I also used the settings that "ARAX" listed on his site (very helpful info), the vtec comes engages too early but im not goin to touch it untill i hit the dyno. Thanks to all those who were helpful on here
Old Feb 13, 2003 | 07:47 PM
LordVtec's Avatar
Default Re: . (3gLudeH22A)
Glad you sorted out the whole thing..
Old Feb 13, 2003 | 09:36 PM
Que_Lude's Avatar
Try to get all of your HP mods done, then hit the dyno for the tune. Good to hear that you solved your issues...
Old Feb 13, 2003 | 09:44 PM
3gLudeH22A's Avatar
Default Re: . (Que_Lude)
:Grin: HP mods have been done for a while.
soto2635
Oct 6, 2006 10:29 AM
soto2635
Sep 25, 2006 02:53 PM
mugenracer
Feb 5, 2003 05:11 PM
