Mugen MF10 wheel's
Old Feb 12, 2003 | 08:57 PM
All Motor TypeR 133's Avatar
Default Mugen MF10 wheel's
Which is the best offset out of to two that they come in for a Type R with 215/45/16 or 215/40/16, most liky the falken azenis?Thanks
Old Feb 12, 2003 | 09:01 PM
zer0zer0 TypeR's Avatar
Default Re: Mugen MF10 wheel's (All Motor TypeR 133)
uhh i'd say 215-45 considering they don't make 215-40 azenis
Old Feb 12, 2003 | 09:04 PM
ya i know that about the azneis, but what iam asking is what offset on the wheel's , should I go with, the 43 or the 50
Old Feb 13, 2003 | 12:38 AM
EPGONZALEZ's Avatar
i run the 43's but the fenders need some trimming
mugen rec. the 50's
Old Feb 13, 2003 | 07:54 AM
Austin's Avatar
Default Re: Mugen MF10 wheel's (EPGONZALEZ)
mugen rec. the 50's
I run the +43mm...with the 215-45/16 Azenis I had some rubbing on the inner front fender(body)...but the rubbing was slight. Mugen recommends +50 for street, and +43 for track...I bought mine used before I had any clue...but for the amount I paid it didn't matter .
Austin
Old Feb 13, 2003 | 09:11 AM
Big Phat R's Avatar
I have 225/40 street tires on the +50 mm offset 16x7 MF-10s. No rubbing that I can detect.
The +43mm offset push the rim outwards 7 mm - so the widest you can go on those is 215/45 unless you roll the fenders in the rear.
Old Feb 13, 2003 | 09:38 AM
IGGY's Avatar
Default Re: Mugen MF10 wheel's (Big Phat R)
Sorry to jump on the band wangon, but what if they were 15x7 what would be the offset for 225, +50?
Old Feb 13, 2003 | 09:46 AM
just4show's Avatar
Default Re: Mugen MF10 wheel's (IGGY)
I would run 50, especially if MOOOOgen recommends that
Old Feb 13, 2003 | 09:51 AM
Big Phat R's Avatar
15X7 are available in one offset only - if memory serves. can't remember which one though.
the 15x6.5 MF-10s are available in two offsets like the 16"s
Old Feb 13, 2003 | 10:10 AM
IGGY's Avatar
so with 15x7 would you be able to run 225's?
Old Feb 13, 2003 | 10:23 AM
Bob#455's Avatar
That's mostly correct... I had Mike M. do some research into 15" MF-10 for me, and according to King the 15x7 come only in bronze and only in 43mm offset. The 15x6.5 come in bronze or silver and in 45mm offset.
Old Feb 13, 2003 | 10:25 AM
Bob#455's Avatar
No you wouldn't, but with 205/50 as wide as the Azenis, why would you need to?
Old Feb 13, 2003 | 11:15 AM
Chris EK's Avatar
I use +43
Old Feb 13, 2003 | 11:37 AM
FAST4DR's Avatar
Default Re: Mugen MF10 wheel's (Quickteck)
Dont forget that the contact patch on the Azenis is larger than most - 215 Azenis will rub when another tire may not - Azenis are at the wide end of the scale.
Old Feb 13, 2003 | 06:52 PM
Big Phat R's Avatar
Default Re: Mugen MF10 wheel's (Bob#455)
Here's what they come in:
I have the +45 offsets
Old Feb 13, 2003 | 07:49 PM
Bob#455's Avatar
Thanks for the pic!
Old Feb 13, 2003 | 08:47 PM
JDM CTR '00's Avatar
nice box lol
Old Feb 14, 2003 | 10:07 AM
IGGY's Avatar
Not with Azenis, but A032R's.
Old Feb 14, 2003 | 10:10 AM
Chris's Avatar
Bob, tell them about your Azenis, and all the smoke they were creating at the track...
because of RUBBING...
Old Feb 14, 2003 | 11:21 AM
Big Phat R's Avatar
Default Re: Mugen MF10 wheel's (Chris)
He's rubbing because the springs on his car are too soft for severe track use - getting too much compression/body lean
digitalightkenz
Wheels
Aug 19, 2014 01:48 PM
CRVEF8
Wheels
13
Sep 20, 2010 06:30 PM
adddddaaammmm
Oct 17, 2004 11:59 AM
Eric R
Nov 4, 2003 09:48 AM
