where are the vss and back up light switch...............
Old Feb 12, 2003 | 08:40 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Default where are the vss and back up light switch...............
I wanna do my cluster swap (gsr) but i dont know exactly where the vss is, i have a stock motor d15..........could someone help me plz
email me
send me pics if available
also i would like to know
where the back up light switch is
Thanx Latrz
[Modified by MR.RED'89, 4:37 AM 2/13/2003]
Old Feb 12, 2003 | 08:47 PM
Full-Race Henry's Avatar
Default Re: where are the vss and back up light switch............... (MR.RED'89)
the vss is on the tranny
Old Feb 12, 2003 | 08:51 PM
Rywire's Avatar
the back up light switch screws into the tranny, 2 wires are comming off of it. Ryan
[Modified by droppedcrxsi, 5:51 AM 2/13/2003]
Old Feb 12, 2003 | 11:07 PM
Toptul_Honda's Avatar
New User
Default Re: where are the vss and back up light switch............... (droppedcrxsi)
look under your starter, there should be a cable coming from the firewall to the tranny. that is the VSS
Old Feb 12, 2003 | 11:51 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: where are the vss and back up light switch............... (EF8_Fan)
wait a min.. assuming he's still single cam, or whatever engine he has, if he's OBD0, he's got a cable driven VSS, and will not have wires. The only VSS signal would be comming from the cluster to the ECU.. riiiiight?
Old Feb 19, 2003 | 09:01 PM
Default Re: where are the vss and back up light switch............... (Built B16A)
no, the vss goes from the cluster to the tranny
Old Feb 20, 2003 | 01:37 AM
Built B16A's Avatar
email me
so basicly, you wanna get a OBD1 or up cluster in your 89?
i can help you wire it up, but i don't know about making it fit.. i doubt its the same lay out.. have you tired it? you have a 89, so maybe a 90-91 hood? and brakets? i dont' know..
your looking at the same swap i am.. getting a non cable driven speedo in your ride.. you will have to find a D series 92 and up speed sensor, and wire it to your cluster.. 3 pin i belive.. 1 hot, 1 signal, and 1 ground.
Your cluster now is cable driven.. you need to upgrade to VSS, to get the cluster its signal.
Old Feb 20, 2003 | 01:43 AM
Built B16A's Avatar
this is a B series cable tranny.. yours would look similar..
Old Feb 22, 2003 | 05:54 PM
SLOW4drINTEG's Avatar
i have a jdm itr cluster in my 90 integra (non-ODB) and i did convert to the electrical VSS...but since the cable vss sends a signal to the ecu...everytime i brake from 60+ the check engine light would come on...and it shows da its VSS Problem because the ecu is not getting the speed pulser signals...anyway to fix this? or override the speed pusler on the ECU? i've been trying to figure this out =T i think its keeping my vtec from kicking in too....
[Modified by SLOW4drINTEG, 2:55 AM 2/23/2003]
Old Feb 22, 2003 | 07:09 PM
PimpTightSi's Avatar
Default Re: where are the vss and back up light switch............... (SLOW4drINTEG)
The VSS is on the tranny you should see it as soon as you pop the hood ... The speedo cable is what goes from the top of your tranny too your cluster..if u look by your rear motor mount there should be a wire going to the top of the tranny... thats the speedo cable...
Nightfox
Nov 20, 2007 06:22 PM
jacoop86
Jul 4, 2006 09:30 PM
wickedEFguy
Dec 16, 2002 03:51 PM
B20zvtecek
Nov 20, 2002 06:30 AM
juicy.koreans.suck
13
Nov 13, 2002 06:40 AM
