Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
st bar install w/o cutting off weld nuts??
Old Feb 12, 2003 | 06:07 PM
Lo-Buck EF's Avatar
Default st bar install w/o cutting off weld nuts??
has anyone installed tokico 5 ways and suspension tech. rear bar? i know ur supposed to cut the weld nut off the shock, but i was wondering if u could possibally turn it around and use the weld nut??
-spenc
edit for spelling
[Modified by SOLOef, 10:08 PM 2/12/2003]
Old Feb 13, 2003 | 03:44 AM
-DC2-'s Avatar
Default Re: st bar install w/o cutting off weld nuts?? (SOLOef)
well, in the instructions, they tell you to rotate the rear shocks 180deg, so the weld nut faces the rear of the car. then, the endlink bracket mounts to the side of the shock w/o the nut (facees front of the car)
you can kinda see what i'm saying in this pic:
Old Feb 13, 2003 | 06:59 AM
Lo-Buck EF's Avatar
Default Re: st bar install w/o cutting off weld nuts?? (DOHCDX)
on the 4th gen civics i think the new bolt for the endlink bracket is differant. i have to gove the instructions a look again, but i remember watching this being cone on a crx and i think the weld nut had to be cut off. but im not sure.
-spenc.....confused
Old Feb 13, 2003 | 07:15 AM
-DC2-'s Avatar
ok, yeah, i dunno about 4th gens. sorry.
Old Feb 13, 2003 | 03:48 PM
jasyatz's Avatar
Spence,
I tried every configuration I could think of and it wouldn't fit using the existing hardware supplied.
If you spin the shocks so the welded nut is in the front, and went down to your local ACURA dealer and bought ITR rear shock bolts, it will work. The ITR bolts are longer than the factory Civic and Integra bolts. From what I found is that if you cut the nut off the shock and double nut the bolt they give you (which is the correct length), the nuts will never come loose. The reason you HAVE to cut the wleded nut off is that the threads are a different pitch on the longer bolts supplied and will NOT thread into the stock (or aftermarket) shocks.
The ITR bolts will work though, if you want to go that route..
Call me at the shop tomorrow, 973-696-5700 I'll be working on Tony's car, but can look them up for you and get them out to you. If you need them sooner (and I have them) you can hal over and pick them up..
Jeff
Old Feb 13, 2003 | 09:45 PM
kefka's Avatar
Default Re: st bar install w/o cutting off weld nuts?? (jasyatz)
Old Feb 14, 2003 | 02:35 PM
eccentric.ek's Avatar
Default Re: st bar install w/o cutting off weld nuts?? (Madein_Japan)
nice lca'a man dam , nice set up
Old Feb 14, 2003 | 03:44 PM
Lo-Buck EF's Avatar
cool jeff. i dont need those bolts just yet. i dont want to run the bar at vir next weekend. but once i get back, ill get intouch with you about pickin up those itr lca bolts. i realy dont wanna cut the nut of my brand new shox.
thanx again jeff
-spenc
Old Feb 14, 2003 | 11:08 PM
kefka's Avatar
Default Re: st bar install w/o cutting off weld nuts?? (redUSDMhb)
Old Mar 22, 2003 | 03:55 PM
Lo-Buck EF's Avatar
ok. i tried to install the bar today and ran into the following...
1. the itr shock bolts i got must not be correct because they didnt work at all. they were in fact shorter than the stocker (which seem to work)
2. the bolts to attach the brackets to the car didnt thread into the car. i had to use the ones that held in the tow hooks that had to be removed in order to put in the brackets.
3. the bar doesnt seem to go in because the muffler is in the way. im gonna try it again after work/tomorrow and see if i can get it to work. but if not, its off to the muffler shop on monday.
-stressed spencer
Old Mar 22, 2003 | 05:34 PM
Eee Pee's Avatar
Bummer. Good thing a rear bar is worth it.
Old Mar 22, 2003 | 06:07 PM
tom_l's Avatar
[QUOTE]ok. i tried to install the bar today and ran into the following...
2. are you sure you are choosing the right bolts? they give you a lot of bolts to use. they should be the black ones that require either 17mm or 19mm socket.
3. is the bar upside-down? compare it w/ your stock one and how it mounts. when it is mounted correctly, the sticker will probably be upside-down. that's how it is on my car. don't know why they did this.
Old Mar 22, 2003 | 07:25 PM
Lo-Buck EF's Avatar
Default Re: st bar install w/o cutting off weld nuts?? (tom_l)
dont think i used the wrong hardware, but ill check again. i tried the bar both ways and just now with the exhaust off. the exhaust is in the way where it comes over the lca and all. its 2 1/4 too, so its honkey. i have to have the muffler shop cut it out so ic an but the bar in. then have them make up a new rear section that will fit
-spenc
Old Mar 25, 2003 | 03:22 AM
Lo-Buck EF's Avatar
i finally gave up and cut the axleback out. bar went in super easy that way.
Old Mar 25, 2003 | 10:39 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: st bar install w/o cutting off weld nuts?? (panda power)
nice 4th gen.
Old Mar 25, 2003 | 11:02 AM
91SiKen's Avatar
Default Re: st bar install w/o cutting off weld nuts?? (Ham'ed Hatch)
When I originally installed my ST sway bar, I knocked the nuts off my shocks like it said. When I just installed new shocks, I just reversed them and threaded the bolt into the nut on the Koni's no problem. On the one side that is. The other side has a different bolt (seize incident ), and didn't tighten properly in the nut on the shock. All I did was tighten as much as possible and then threaded on the nut that came with the sway bar as a lock nut. I know that this doesn't make sense, if the bolt works on the one side, and the nut from it works on the replacement bolt, why doesn't the replacement bolt thread right? I don't know, but it works good so far. If it falls apart on me I'll let you all know
:edit: My Thermal exhaust had to be altered as well, it kept banging and vibrating against the bar. Actually broke one of the hangers off even after a mild tweak. After a second go at it, all is good, no more rub. Obviously have em bend the hangers, not the tubing.
BTW, anyone know the best way to get new endlinks for this swaybar? Mine are shot. Pegasus? ST? Anybody have a kit with better parts?
[Modified by 91SiKen, 8:10 PM 3/25/2003]
Old Mar 25, 2003 | 12:07 PM
Lo-Buck EF's Avatar
Default Re: st bar install w/o cutting off weld nuts?? (91SiKen)
i had them redo the acke back to moove it over about an inch. its all good now. bar feels good too. ill get to play with it this weekend and see how it realy performs.
-spenc
Old Mar 25, 2003 | 10:25 PM
Ham'ed Hatch
Guest
Posts: n/a
is there any way one of you guys who have the 88-91 ST bar to get a pic for me? i need to know where it will sit, so a good pic of the whole bar installed from different angles would be great...
Old Mar 26, 2003 | 12:19 PM
Lo-Buck EF's Avatar
https://honda-tech.com/zerothread?id=451282
hope that helps.
-spenc
ps-if u have any other questions about how it sits (if the pics arent enough, which they prolly arent) feel free to ask. i can go int detail since i spent alot of time staring at that thing
propwdialogue
Dec 14, 2010 12:06 AM
i-VTEC_DOHC
Honda Civic (2006 - 2015)
26
Jul 14, 2009 03:04 AM
Lo-Buck EF
Jan 19, 2004 06:45 PM
uncleben
14
Mar 24, 2003 10:27 AM
FourthGenHatch
15
Aug 2, 2002 08:12 PM
