little lighting problem
Old Feb 12, 2003 | 12:41 PM
JaiDM's Avatar
Default little lighting problem
ok, well my corner light the one with 2 bulbs next to head light.
the outer one does not work, this is only on the pass side. its
not the bulb, i seems like it s a relay or something, but its only
that one light, its like there is a short.
when if 1st started to happen, it would not turn on at all then once
in a while it would turn on and not turn off, even after you turn
your lights off.
it must be some kinda of short. any ideas? anyone?
thanx!!!
Old Feb 12, 2003 | 01:03 PM
Perfectionist's Avatar
Default Re: little lighting problem (JaiDM)
Not a short, or a fuse should blow. More likely an open circuit. Check the condition of the socket itself and even the wiring going to it.
Old Feb 12, 2003 | 01:22 PM
JaiDM's Avatar
Default Re: little lighting problem (Perfectionist)
how can i check the condition?
SiMPLESi00
Apr 10, 2011 08:31 PM
Metal Typhoon
Oct 17, 2006 05:14 PM
2.2L EH2
Oct 10, 2006 11:10 PM
integrx
Jan 27, 2004 03:12 AM
Ideal
Jan 6, 2004 01:43 PM
