Earl's brake bleeders - any experience?
Old Feb 12, 2003 | 11:48 AM
Dan's Avatar
Dan
Default Earl's brake bleeders - any experience?
has any one tried these?
http://store.summitracing.com/defaul...%2Easp%3Fd%3D4
Old Feb 12, 2003 | 11:54 AM
typer_801's Avatar
Default Re: Earl's brake bleeders - any experience? (Dan)
My old roommate used the Earl's and had troubles with them, couldn't get a firm pedal. We eventually took them off, and conventionally bled the brakes to get them right. I OTOH used the Russell brand ones and never have had any issues. I ordered mine from Jegs btw.
Old Feb 12, 2003 | 11:59 AM
onyx00's Avatar
Default Re: Earl's brake bleeders - any experience? (typer_801)
I like speedbleeders http://www.speedbleeder.com
Work great for me.
Old Feb 12, 2003 | 01:35 PM
mrlegoman's Avatar
Default Re: Earl's brake bleeders - any experience? (onyx00)
In using ANY kind of speed bleeder you need to remember that you only have to open the bleeder 1/4-1/3 of a turn. Any more and your risking letting air in which equals squishy brakes. I would say that 90% of the complaints I get are solved because they where opeing them almost a full turn to bleed.
The SpeedBleeders brand comes with a sealent on them too for a better seal.
Old Feb 12, 2003 | 01:36 PM
Chris N's Avatar
Default Re: Earl's brake bleeders - any experience? (mrlegoman)
That explains my brakes right now....
Old Feb 12, 2003 | 05:44 PM
mrlegoman's Avatar
Default Re: Earl's brake bleeders - any experience? (Chris N)
The Speed Bleeders are exactly the same as the OEM bleeder when closed! So when your bleeding and your getting air in there check your sealent on the threads and make sure your threads are not starting to strip. The regular OEM and Speed bleeders are not meant to be torqued higher than 32-40 in-lbs.(not ft-lbs!).
[Modified by mrlegoman, 6:48 PM 2/12/2003]
Old Feb 12, 2003 | 07:04 PM
1SlowB16EF's Avatar
big up for gravity bleeding... its the best and easiest if you have the time!
Mr_Sixx
Suspension & Brakes
Oct 7, 2010 08:14 AM
ltante
Nov 26, 2009 07:57 PM
trianglegreg
12
Dec 8, 2006 06:55 PM
benson03
Feb 20, 2006 09:05 AM
IGGY
Mar 3, 2003 07:48 PM
