spark plug choice
Old Feb 12, 2003 | 09:39 AM
[HrZn]4life's Avatar
Default spark plug choice
Only I/H/E on my car. Should I stick with stock plug or go one step colder? Thanks.
Old Feb 12, 2003 | 09:51 AM
Eva01's Avatar
Default Re: spark plug choice ([HrZn]4life)
Stock plugs. No reason to go colder unless you up the compression ie FI or higher compression pistons. HTH
Old Feb 12, 2003 | 11:08 AM
B2FiNiTY's Avatar
stock NGKs
Old Feb 12, 2003 | 06:35 PM
gsr-2nr's Avatar
Default Re: spark plug choice (B2FiNiTY)
denso iridiums
Old Feb 12, 2003 | 06:50 PM
96dc2's Avatar
Default Re: spark plug choice (gsr-2nr)
denso iridiums
wasting money.
Old Feb 12, 2003 | 07:21 PM
98itR484's Avatar
Default Re: spark plug choice (96dc2)
bosch 4227's $1.99 each Works great for me, however for some it does not
Old Feb 12, 2003 | 07:23 PM
BlueR's Avatar
Default Re: spark plug choice (98itR484)
stock plugs own
Old Feb 13, 2003 | 09:47 AM
Default Re: spark plug choice (BlueR)
Well, found some iridiums for a good price, so I decided to just give them a try. I know a lot of people are very skeptical about the denso iridiums but I noticed an obvious improvement. I went from fresh stock ngk's to fresh denso iridiums and that is why I know the improvements were substantial. Idle smoother, accelerate smoother, lil bit of extra kick. Anyways, butt dyno is not the last word; i'll be getting my car dynoed pretty soon and i'll do a comparison (fresh stock vs. fresh iridiums) for you guys. Thanks for all the opinions though.
Old Mar 19, 2003 | 09:44 AM
6ghatch's Avatar
OT, but you guys know your stuff. Does anyone know why the B18C5 uses a 1.1mm or .043 gap where the B18c1 and B16A2 use a 1.3mm or .051 gap? Also, does anyone know what the difference between the PFR6G-11 vs. PFR6L-13, beyond the gap size?
It's just that my Denso plugs after 20,000 miles are white as a ghost. Which says I'm either running hot or lean. I'm running skunk2 stage 1 cams, all the bolt on's and A/F tuned to 12:1-13:1. Any plug suggestions?
[Modified by 6ghatch, 1:59 PM 3/19/2003]
Old Mar 19, 2003 | 09:57 AM
blykins's Avatar
Banned
Default Re: spark plug choice (6ghatch)
OT: but does anyone know why the B18C5 uses a 1.1mm or .043 gap where the B18c1 and B16A2 use a 1.3mm or .051 gap? Also, does anyone know what the difference between the PFR6G-11 vs. PFR6L-13, beyond the gap size?
[Modified by 6ghatch, 1:51 PM 3/19/2003]
white means lean, black means rich.
Old Mar 19, 2003 | 11:18 AM
98TypeR's Avatar
Default Re: spark plug choice (blykins)
ngk bkr6e11
Old Mar 19, 2003 | 11:40 AM
YellowR2000x2's Avatar
Default Re: spark plug choice (98TypeR)
so which plugs would be a good choice for what im running? built 2l with 12:1 C/R? its already been tuned so should i just keep using the plugs we tuned with or should i change to a different kind? stock ones are on there now...
Old Mar 21, 2003 | 04:53 AM
Mns's Avatar
Mns
Don't gap your plug anymore
Take multispark plug
Take a look here http://plugs.janmax.com/premiumtable.aspx
Old Mar 21, 2003 | 05:07 AM
Mns's Avatar
Mns
I agree with you about denso iridium, but one thing about design:
"By looking at design, I would say BRISK product would perform better, because it is a surface cap with no ground electrode to slow down the expansion of the ignited fuel mixture..."
Old Mar 21, 2003 | 05:26 AM
azn98R's Avatar
denso iridiums
wasting money.
agree... been there, done that, and won't do it again
Old Mar 21, 2003 | 08:51 AM
Trellis's Avatar
Platinum Plus 4 No need to gap
Works fine for me!
[Modified by JuzOmni, 12:52 PM 3/21/2003]
Old Mar 21, 2003 | 09:28 AM
cw98typer's Avatar
Default Re: spark plug choice (JuzOmni)
anybody else running platinum 4's. Or would NGK platinum be better for my setup.
Old Mar 21, 2003 | 09:34 AM
Mns's Avatar
Mns
ignited fuel blocked by 4 electrodes. Old design and technology.
Old Mar 21, 2003 | 09:39 AM
TsunamiZC's Avatar
Works fine for me!
Bosch 4 are crap ...ran them on my G1 ....they started idling rough after 4 months ...ran them in my dad's cressida ..they fouled ....and a peice of metal broke of the contact ...scared the cylinder head ..ended up losing compresion ....a month later head gasket blew ....
they foul to quickly ..
they work good on VW's Audi's ....
sorry to be racist but
German Plugs with German cars
Japanses Plugs with Japanses car ...
thats just the way it is
Old Mar 21, 2003 | 09:54 AM
sgT's Avatar
sgT
Dont bother looking at your spark plugs to check a/f mixture.
Old Mar 21, 2003 | 10:24 AM
Mr.Integra's Avatar
denso iridiums
wasting money.
o yea? and why is that?
Old Apr 2, 2003 | 09:39 AM
Sam's Avatar
Sam
Default Re: spark plug choice (Mr.Integra)
So, what's the part # of the stock plugs? And where can I get it cheap??
Old May 2, 2003 | 12:05 PM
KJ's Avatar
KJ
Default Re: spark plug choice (tsunami_zc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Hahaha, that's why my 2002 BMW M3 has NGK plugs that were designed specifically by NGK for my car right?
In case you're wondering why I'm here, I used to own a Type-R (and found this board to be very informative compared to the M3 boards). Some M3 guys are looking into Denso Iridium's over the stock NGK's. I remember one of the members here said he lost 5whp from Denso Iridium's so I'm just trying to see if there was any more information regarding that.
- KJ
Old May 2, 2003 | 12:48 PM
Tweakmeister's Avatar
Default Re: spark plug choice (KJ)
anyone index their plugs?
seems like a major PITA for what little performance gains...and you factor in the mix should be well mixed in the cylinders by the time it is ignited.
accord99power
Oct 21, 2008 08:06 PM
Jcup315
Apr 18, 2005 06:08 PM
Aeka GSR
Dec 5, 2003 10:14 AM
Casey
Mar 19, 2002 07:00 PM
