Check engline light on ITR
only owner of the car i can honestly say i havent bagged on my car 2 much maybe alittle when i got it nothing extremely stupid...It just started blinking and i just had the oil changed but after a few kms it started blinking??anyone help?
hmm well thats weird casue i just had the oil changed and crap.... i guess ill just take it back to the dealership where i get it changed..is it true even if yer gas tank lid is fully sealed or oil rod isnt in properly that light would be on...thx anyhow
It is possible for your CEL to blink a misfire would cause this
check for any codes stored in your PCM memory if it is your CEL that your talking about.
u were so ******* right!! outlaw R it is my 4th cyclinder that is misfireing i think i counted many times came up with 74....ahh thx guys!!! anyone know how much this could cost?
Also, have you washed your engine bay lately? You can get moisture into the top of the spark plug hole which can cause a misfire. You'd need to blow the water out with an air compressor.
I have a feeling you'll find out more about it when you pull the #4 plug..
Yes, i have washed my engine bay latley!!..ill have to take a look at that after work HMMM...anyhow i still got warrenty so it would cost me nothing...but ill take a look thx
for all your newbie outhere if the check engine light blinks that means that you have a missed fire. check to see if your wires aren't touching anything and check spark plugs
i know the code its cycliner 4 that is mis fireing and i believe water has gotten into it and i neeed to know how to get it out??it is propbley running through the oil right so maybe if u just changed the oil would that help?
tacchan
25
Apr 5, 2010 06:37 AM
. theres a maint light reset button. its green. under the dash. below the steering wheel.
