Which Distributor to use? Im so confused..please clear it up for me
Old Feb 11, 2003 | 09:23 PM
GummyBeng's Avatar
Default Which Distributor to use? Im so confused..please clear it up for me
Engine is B16a2.
I need a distributor, preferably OBD1, but OBD2 will also do.
Could someone please tell me which ones i can definitely use?
Need to place an order with my mechanic soon...please help me out guys!
Thanx
Old Feb 11, 2003 | 10:47 PM
IWearMyKswiss's Avatar
New User
Default Re: Which Distributor to use? Im so confused..please clear it up for me (GummyBeng)
depending if you motor is OBD2 or OBD1,..if you got a b16 out of a 99-00 SI then you can use an SI,...GSR,..or Type R distributor
Old Feb 11, 2003 | 10:51 PM
jdmWONG's Avatar
Default Re: Which Distributor to use? Im so confused..please clear it up for me (WiDeBoDyEK)
depends on what car your puting the b16a2 into, and what ecu your running. if you have a obd1 car and ecu than use a obd1 dist. If you have a obd2 car and ecu, than use a obd2 distr.
Old Feb 12, 2003 | 01:03 PM
dogpile5's Avatar
25 Year Member
Default Re: Which Distributor to use? Im so confused..please clear it up for me (Blow'N'CRX)
everyone is charging an arm and a leg for a obd1/2 distributor for the vtec motors. poor me hacked one of the legs off a b18b distributor and it worked perfectly fine. i have recommended this for a lot of guys that for some reason did not get a dist with their swap, or are trying to make an older engine work in a newer car.
just make sure you got that bitch on tight, or your timing is gonna go all over the place!
Old Feb 12, 2003 | 02:17 PM
chet's Avatar
Default Re: Which Distributor to use? Im so confused..please clear it up for me (dogpile5)
around here i see used obd1 distributors for less than 100 regularly.
i'd go with OEM honda, and find a dohc vtec distributor. where are you located...i'd check your local boards...you'll find someone selling one.
ej8_fredi
Mar 28, 2009 11:10 PM
bb6_00
Jan 18, 2009 06:17 AM
DJNauTicz
Sep 21, 2005 05:14 AM
FritzInTN
Mar 8, 2004 11:39 PM
h22acivic4u
Jul 8, 2003 10:18 PM
