Car vibrates - could it be an axle?
Old Feb 11, 2003 | 08:02 PM
drjondurst's Avatar
Default Car vibrates - could it be an axle?
I replaced my passenger axle with a Autozone axle about maybe 2-3 months ago. I cant really remember if my car would vibrate like it does now before the axle job, but could the axle be whats causing it? Im thinking so because I used a sledge to whack it into the tranny and later found out that could damage the bearings or something. My car also pulls to the right pretty hard (have to use a little muscle to drive straight) and Im guessing an alignment would fix that.
God, if I could just have a genie grant me one wish, it'd be to have my CRX run perfectly smoooooth with none of this bullshit. BTW, it starts to really vibrate around 55mph+.
Old Feb 11, 2003 | 08:07 PM
MADEINIRAQ's Avatar
Default Re: Car vibrates - could it be an axle? (drjondurst)
make sure the big nut on the axle is tight
Old Feb 11, 2003 | 08:12 PM
drjondurst's Avatar
Default Re: Car vibrates - could it be an axle? (madeiniraq)
the axle nut is pretty damn tight, it had a 265lb male jumping on a breaker bar to tighten it.
Old Feb 11, 2003 | 08:13 PM
DA MUGEN 1's Avatar
Why the hell did you use a sledge hammer to hit it in My guess if you hit it pretty hard and the car didn't pull to the right before you put it in and it didn't make a rattle noise before you F***** something up!
Old Feb 11, 2003 | 08:14 PM
drjondurst's Avatar
Default Re: Car vibrates - could it be an axle? (DA MUGEN 1)
I was dumb and didnt get enough info on the install before I did it. Good thing is its got a free lifetime warranty, so if enough people think the axle is the problem, Im gonna get it replaced.
Old Feb 11, 2003 | 08:21 PM
ameenit's Avatar
Well before you diagnose the axle as the problem, check the other things..like the screws holding on the rotor, the lug nuts, the big bolt where the lower control arm and strut meet, tie rod, etc... if all those are in good shape and nice and tight then go get another axle from autozone. See if that will fix it..
I had a simular problem and it turned out that the rotor bolts were coming out due to vibration and then the whole car would shake when i would make a turn over 30mph. Well i tightened them up and put some thread lock on it and havent had a problem since!
Old Feb 11, 2003 | 08:33 PM
drjondurst's Avatar
Default Re: Car vibrates - could it be an axle? (crxaccord)
rotor bolts? those arent the axle nuts are they?
Old Feb 11, 2003 | 08:37 PM
ameenit's Avatar
no my bad, i meant the rotor screws, you know, those 2 phillips screws in the rotors.......
Old Feb 11, 2003 | 08:59 PM
drjondurst's Avatar
oh **** man u serious? that could cause vibrations? Mine are real loose.. I moved one of them with my finger once while I had my wheel off.. damn if I tightened them it might stop the vibrating? You've gotten my hopes up thinking that maybe its such a simple fix.
Old Feb 11, 2003 | 09:28 PM
MIRRAdekhtc's Avatar
glad i seen this thread just now. i just got this crx last week, lowered it the other day with coilovers it rode like ****, needs tokico's all the way around, and a CAMBER KIT, so i put it back to stock the next day, until i get struts, but now on the highway i noticed the same **** around 55+, it feels like the right front strut is shimmying, left to right, i checked all the suspension bolts, retightened all of them, thinking maybe one of them wasn't completely tight, they were. Like on the highway anywhere from 50-60mph, in a gradual turn or exit ramp even at 35mph, it vibrates and shimmies pretty bad, its kinda scary, i know for a fact it didn't do that before i lowered it, its not the whole front end doing it, i can feel it, its just the right front, for what it sounds like, it sounds like if you were to loosen the top 2 bolts on the strut alittle bit, it sounds like the strut is loose, but its not, i guess i'll recheck everything.
Old Feb 11, 2003 | 09:30 PM
ameenit's Avatar
Well i dont want to get your hopes up, but if that is the problem then i guess i will be your "genie"
GOOD LUCK!!
Old Feb 11, 2003 | 09:37 PM
CAMBER KITS
my crx had HELLA camber, real bad, even at stock height it looks alittle cambered, is this normal for crx's?? I'm not gonna drop it till i get a camber kit, any recoms.
Old Feb 11, 2003 | 09:40 PM
Vinceg99's Avatar
Those 2 screws dont do anything I HIGHLY doubt they would be the problem there are only there to hold the rotor on while its on the assembly line. I havent put those things in whenever I did a break job and I have never had a probelm your caliper and rim is what holds the rotor in place.
[Modified by Vinceg99, 1:18 AM 2/12/2003]
Old Feb 11, 2003 | 09:43 PM
ameenit's Avatar
Default Re: Car vibrates - could it be an axle? (Vinceg99)
dude, if the caliper was holding the rotor in place, then you would hear a grinding noise all the time when you drive. The caliper only makes contact with the rotor through the pads when it is time to stop. The thing that DOES hold the rotor on are those screws and the wheel. I seriously tightend those screws and my problem was fixed..
Old Feb 11, 2003 | 09:57 PM
ameenit's Avatar
im not "second guessing" you nor am i arguing with you. All i am saying you have some BADASS brakes if they dont move around when you have the wheel and those screws off! Where can i get a set of those?
Old Feb 11, 2003 | 10:17 PM
drjondurst's Avatar
Haha ok, calm down. Im going to tighten these rotor screws tomorrow after school and post back with you guys. Im also gonna tighten up all of my suspension bolts. Anyone got the torque specs on all of them handy?
Old Feb 11, 2003 | 10:22 PM
Vinceg99's Avatar
Well then your piston sure retracts pretty far back into your caliper if you can move it all around.
Here are 2 different posts that people have said they same thing get rid of the bolts they dont do much especially after the rim is back on.
https://honda-tech.com/zerothread?id=347243
https://honda-tech.com/zerothread?id=222739
Old Feb 11, 2003 | 10:25 PM
I_love_my_Crx's Avatar
i had that same problem when i first replaced an axel...turned out that i damaged the bearings inside the tranny where you put in the axel...and i had my mechanic replace them...if i recall it wasnt too expensive....also check and see if it is leaking oil around that area...
Old Feb 11, 2003 | 10:37 PM
drjondurst's Avatar
Default Re: Car vibrates - could it be an axle? (I_love_my_Crx)
Lets hope not. Could you find out what those bearings are called?
Old Feb 11, 2003 | 10:42 PM
SEA Hag's Avatar
My Helms says you can leave the screws out if they are even there because they are only used on the assembly line...
Old Feb 11, 2003 | 10:45 PM
ameenit's Avatar
Default Re: Car vibrates - could it be an axle? (SEA Hag)
ok well i guess i had another problem then... my bad
Old Feb 11, 2003 | 10:52 PM
drjondurst's Avatar
Damn! Im actually betting your problem was just loose lug nuts or something.
Old Feb 11, 2003 | 11:04 PM
EG8R's Avatar
You don't really need those screws. TRUST ME!!! Have you checked wheel balance??? Just guessing here....
Old Feb 11, 2003 | 11:13 PM
gray89si's Avatar
One or both of your tie rod ends is more than likely worn out. Do you notice the pull under braking too?
Old Feb 11, 2003 | 11:16 PM
Default Re: Car vibrates - could it be an axle? (mr. skelly)
well, don't know who your referring to, but i know for a fact my wheels are balanced, just put new tires on all 4, balanced, so i know its not that, someones first impression would be an out of balance wheel, but the fact that it started doing it after i lowered it, puzzled me, something is loose somewhere.
