will a 00' si cluster help my problem
i have a 96 dx hatchback, with a 00 si motor and si ecu and harness, the car was a 4speed and now a manel , so the computer is making the car think its in park from the stock cluster....so the mph gauge dont do ****..is a si cluster all i need for that damn thing to move
Using an Si cluster is not a solution to your problem. Did you use an OBD2 to OBD2.5 conversion harness or did you just use the Si harness and rewire the odd plug? It sounds like a wiring problem to me.
Doesnt sound like a cluster problem. I wll garantee the problem is because you are using the SI harness. I dont think the SI harness will work in the hatchback,
prelude2.2
Mar 3, 2012 01:35 PM
hatchinprogress
Aug 20, 2004 01:50 PM
