air bag problem - help - need advice on what to do
I have a 93 civic coupe EX -
it has a gray steering wheel with airbag
I bought a Black - 1994 integra steering wheel with airbag -
ONLY problem i have , the airbag connector on integra wheel will not work with civic plug
Should i cut the plug from Civic and integra - and put the civic plug in the integra wheel
??? anyone have an idea of what should i do ?>
or take out the wire/pins and slide them out into civic plug ??
there are two wires both red on airbag ?? are they the same ?? anyone know what to do
is it safe to cut and splice ??
Having done this, I can give you some advice.
I spliced, but did not solder.
The airbag may not fire properly if you don't get it hooked up right. (and you can only be absolutely sure if you test fire it).
I don't know of any way to get the plugs to work right without cutting/splicing either on the car or the airbag.
I spliced on the airbag side.
Good luck. Be careful.
Shawn
Shawn
floatfisher
May 16, 2008 09:28 AM
xXx Justin xXx
13
Apr 30, 2003 08:47 AM
allmotorls95
Mar 24, 2003 04:56 PM
