Wanna see some times for......
Old Feb 11, 2003 | 05:41 PM
97itr86's Avatar
Default Wanna see some times for......
Wanna know what you guys with single cam CRX si's with nitrous are running in the 1/4 mile? List your set up.
Old Feb 11, 2003 | 07:31 PM
d-wreck's Avatar
Default Re: Wanna see some times for...... (97itr86)
use to run low 14s with a failing clutch. 75 shot d16a6 intake only. . .
car is much different now.
midhigh 13s low 14s are uncommon with slicks and an average driver
derek
Old Feb 11, 2003 | 07:33 PM
91_hatch_si's Avatar
Default Re: Wanna see some times for...... (d-wreck)
wut times, for a dohc zc, with 50 shot? and street tires
Old Feb 11, 2003 | 07:34 PM
Default Re: Wanna see some times for...... (91_hatch_si)
and a dohc zc just itself?
Old Feb 11, 2003 | 07:46 PM
drjondurst's Avatar
Im curious too.
Old Feb 11, 2003 | 08:04 PM
ameenit's Avatar
Default Re: Wanna see some times for...... (drjondurst)
Didnt he say SOHC though?
Well if you are wondering about the DOHC ZC w/o nitrous i ran a 9.4 on the 1/8th..
Old Feb 11, 2003 | 08:09 PM
drjondurst's Avatar
Default Re: Wanna see some times for...... (crxaccord)
Either u said that wrong or you've got a little more than this done to your car:
DOHC ZC Motor-IHE
Underdrive Pulley
ACT Extreme Clutch
Im curious to see what kinda times ur running cuz I'll have a very similar setup.
Also, when you ordered that clutch for your ZC, did you just order it for the year of CRX tranny you put on the ZC? For example I have a 91 CRX Si.. I just order my clutch/flywheel for a 90-91 CRX and it'll bolt right up to the ZC correct?
Old Feb 11, 2003 | 08:16 PM
ameenit's Avatar
Yes, the Si clutch will work on the ZC transmission. I am not sure about the 88 ones but you dont have to worry about that. And yea i did run a 9.4 with the mods that i have listed . Pretty sure if you do the same mods in a lightweight HF you will get simular numbers
Old Feb 11, 2003 | 09:01 PM
drjondurst's Avatar
oooooh it says the 1/8th. Haha I was thinking it was a quarter mile.. what is your guess as to what you'd run in the 1/4?
Old Feb 11, 2003 | 09:16 PM
MIRRAdekhtc's Avatar
since, were on this topic, i'm kinda of curious too.
90 crx hf, with a 95 ex swap, i.e. 1.6 sohc vtec, si cable tranny, using the hasport wiring subharness with the obd-1 p28 ecu, on stock 14s, new tires, with i/e and new clutch, i'm guessing any where from maybe just maybe a 14.9--15.5
my friends 93 cx hatch, with this same swap and mods was pullin consistent 15.2--15.3 all day, i figure the cx hatch is the lightest of that model, stock its something like 2050lb., my 90 crx hf is a little lighter than that, i'm hoping for atleast a 15.2, i'd be happy with that, atleast for now. Also what do you think that setup would do with a nitrous express wet kit, at a 50 shot?? Might be puttin that on too?? But wanna see how it runs with the motor first.
Old Feb 11, 2003 | 09:28 PM
ameenit's Avatar
HAHAHA... 9.4 on the 1/4 I WISH!! yes that would be a little more then an intake header and exhaust... maybe the crank pulley would do it though.. hehe..
btw.. those are very respectable times you got on a SOHC
Old Feb 11, 2003 | 10:53 PM
well, *** it, i guess were the only ones on this thread, i'll just talk to you, what do you think a 90 crx hf, with the ex setup would pull?? i think i'm being realistic, 15.0--15.5
Old Feb 11, 2003 | 11:17 PM
Default Re: Wanna see some times for...... (MIRRAdekhtc)
im thinking 15.5 maybe 15.3 with some good tires? how much is a ex motor? with tranny? ecu?
Old Feb 11, 2003 | 11:38 PM
well i just had brand new tires put on, 195/60/14 nakangs, semi-cheap performance tires, good bang for your buck.
i'm confident it will hit a 15.3, my friends hatch would pull consistent 15.3 on **** tires, we weigh about the same, equal driving too, and my car stock to stock is about a 100lbs. lighter than his cx hatch.
ex swaps are a dime a dozen, so many people swap them out for gsrs, or b16s, there everywhere, around here you can get a complete swap for anywhere from 500-1000, everything, you can find, for ex: a 94 ex motor(complete), tranny, for like 200-300, get the ecu (p28), 100, swap the hydro tranny for a cable, and bolt her in, and hit a mid 15. not bad, greddy kit for like 1400-1600, at 8-10psi, hella fast for the street, hittin high 13s, my friends 95 ex cpe, with 18's, body kit, full int. stereo and all, was fast, he had a greddy kit on it, used 93 octane all the time, ran it at 11psi everyday, and pulled a new vette on the highway, fast for the street. now he has a gsr in it, built from the bottom up, custom turbo kit, its a low sec. show car now. check it out at http://www.alternativemotorsports.com, the white coupe.
Old Feb 11, 2003 | 11:42 PM
oh ***, i guess they're updating the site, check it out sometime though, or check out http://www.lowerlevel.com, go to shows, lowdown showdown, the white 95 civic coupe, 18s, and the kit***
Old Feb 12, 2003 | 04:16 AM
keithv's Avatar
fyi, to keep this thread on topic, some of the appearance related posts were deleted...so if some of you guys wonder "where did my post go?" you know it was me. please IM me if you have any questions.
thanks and now back to the topic at hand....
Old Feb 12, 2003 | 07:43 AM
USDM 4G VTEC's Avatar
i am not a CRX
i got a HB and with just an intake i ran a 15.9 @ 86..... pretty crappy... i wanted 15.7... but i guess after the header, cat and exhaust i ll be there.. actually the tires i used where crappy also.. so i want better tires next time i go...
hopefully in mid 15's fo sho
Old Feb 12, 2003 | 07:54 AM
ElementMotor's Avatar
My friend ran a 13.4 w/slicks with a dohc zc and a 60 shot.....of course he had a 86 crx si tho......freakin light as hell....
Old Feb 12, 2003 | 09:16 AM
SteveeeO's Avatar
Default Re: Wanna see some times for...... (JDM EF9)
i am not a CRX
what is your elevation ? that time seems pretty high ... did u shift at like 3k rpm or something? a lot of a6's run that time with just intake...
[Modified by SteveeeO, 1:17 PM 2/12/2003]
Old Feb 12, 2003 | 10:31 AM
Default Re: Wanna see some times for...... (EF8 ownz u)
hey ef8
was the crx gutted? or full interior? how light are those crx?
i have a 91 hatch si, if i get a dohc zc, with 50 shot of nos, on street tires, full interior, do you think i would be able to get 14 flat ?
[Modified by 91_hatch_si, 11:34 AM 2/12/2003]
Old Feb 12, 2003 | 10:53 AM
Malgerus's Avatar
I pulled a 15.29 in my 89 CRX Si with a 96 D16Y8 sohc vtec, p28 ecu, bored out tbody, Si trans, homemade CAI, flowmaster exhaust, stripped rear, removed passenger seat. Most of my runs were 15.3' but I pulled the 15.2 in crappy conditions... hot sticky track and mad wheelhop. I think if I could have sorted out the launch I could have managed a 15.1. BTW, the best eigth mile i pulled was a 9.808
[Modified by Mr. S, 11:55 AM 2/12/2003]
Old Feb 12, 2003 | 10:55 AM
0554's Avatar
Default Re: Wanna see some times for...... (Mr. S)
there was this guy at the track with a 91 si crx and a dohc zc with a 50 shot on street tires and he ran 14.3
Old Feb 12, 2003 | 10:59 AM
foesicks's Avatar
Not to get to off topic but my boys 96 lx civic(d16y7) ran a 14.4 with a dry 75 shot. Only mods were open DP ex manifold, stock air box (filter removed) and all the rear seats and carpet were taken out. Oh yeah he also was on 185's
Old Feb 12, 2003 | 11:01 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
i ran a 12.3 cheater slicks.. 100 shot.. 1.8 sec 60"s, 109MPH.
Fully slicked down, 60"s were 1.5 sec., 106MPH, ran a 11.9
5 series block fully built, fully built head, 100 shot, Skunk2 Stage3 cams, ITR intake, and exhaust manifold, open header, no intake.. no weight reduction.. 89 Si
[Modified by Built B16A, 8:03 PM 2/12/2003]
Creepshow S60
10
Sep 28, 2004 06:20 PM
RACING INTEGRATION
22
Jun 28, 2004 07:25 AM
OutLuDeD
Jun 20, 2003 03:20 PM
BseriesHatch
13
Mar 28, 2003 04:46 PM
-=TWITCH=-
65
Jun 13, 2002 01:34 PM
