b16 vavle springs vs b18c5 springs
Old Feb 11, 2003 | 05:20 PM
DOHCTOR's Avatar
Default b16 vavle springs vs b18c5 springs
which ones are stronger, the vavles on a b16 is heavier vs the lighter b18c5 springs? has anyone tested the spring differences?
Old Feb 11, 2003 | 06:09 PM
b19coupe's Avatar
Default Re: b16 vavle springs vs b18c5 springs (DOHCTOR)
B16 uses single valvesprings on exhaust side. ITR uses dual valvesprings on intake and exhaust side. For higher lift, higher rpm operation, the ITR valvesprings are the way to go.
[Modified by b19coupe, 8:19 AM 2/12/2003]
Old Feb 11, 2003 | 07:30 PM
Circuit Star-29's Avatar
Default Re: b16 vavle springs vs b18c5 springs (b19coupe)
Simply put, ITR valve springs have a higher spring rate than any other OEM Honda Valve spring. ITR springs are the perfect street spring because they allow High rpm and high lift without worring about valve float at 8800 rpms.
Old Feb 11, 2003 | 08:14 PM
Wes d's Avatar
Default Re: b16 vavle springs vs b18c5 springs (nathan atwell)
Can the stock B16 spring retainers be used with the itr dual springs?
Old Feb 12, 2003 | 03:47 AM
b19coupe's Avatar
Default Re: b16 vavle springs vs b18c5 springs (Wes d)
B16 retainers are the same part # as ITR retainers. 14765-P30-000.
[Modified by b19coupe, 8:21 AM 2/12/2003]
Old Feb 12, 2003 | 06:12 AM
yobtah's Avatar
Actually, the B16a has dual valve springs on the intake side and single on the exhaust side. The B16a's dual intake springs are the same as the b18c5's exhaust springs.
So... usually people move a b16a's intake springs to the exhaust side and use ITR springs on the intake side.
92integraVTECgsr
Dec 29, 2020 09:15 PM
89EF_Turbo
Jun 7, 2007 06:50 PM
costar
May 5, 2006 08:27 AM
Yosshaa
Dec 8, 2003 09:42 AM
Eyes Only
Aug 22, 2003 10:19 AM
