ground wire confusion =P
Old Feb 11, 2003 | 04:56 PM
Kid1320's Avatar
Default ground wire confusion =P
ok now everyone says the pic below is correct. but it doesnt even touch any part of the valve cover since there's a rubber gourment under where the nut is
and everyone says this one is in correct... but i would figure this is the rightway
since its directly on the metal part of the valve cover
and this one... umm.. yeah....really confused
what is the correct way?
[Modified by Kid1320, 5:58 PM 2/11/2003]
Old Feb 11, 2003 | 04:59 PM
youngkow's Avatar
Default Re: ground wire confusion =P (Kid1320)
<U>what is the correct way? </U>
This is the correct way. There is absolutely no need to ground the valve cover.
Old Feb 11, 2003 | 05:00 PM
steve_s's Avatar
But with the top pic wouldent the wire be touching the bolt which would be touching the valve cover?
Old Feb 11, 2003 | 05:02 PM
blazinb16's Avatar
Default Re: ground wire confusion =P (youngkow)
No reason to ground the valve cover?...then why dose it come from the factory with a ground?
-Whitey-'s Avatar
Default Re: ground wire confusion =P (steve_s)
it goes around the bolt on the valve cover to ground the head not the valve cover..its right in the pic with the blue engine bay
Old Feb 11, 2003 | 05:03 PM
delslow94's Avatar
your not grounding the valve cover your grounding the head. the bolt that it attaches to attaches to the cam which touches the head. the valvecover has rubber on it and such which does nothing. it doesnt receive much current which is why u attach it to the bolt.
Old Feb 11, 2003 | 05:07 PM
Chris y0!'s Avatar
Default Re: ground wire confusion =P (delslow94)
block is ground, valve cover is neutral.
you have a correct ground there kid.
Old Feb 11, 2003 | 05:20 PM
B18EG6's Avatar
Default Re: ground wire confusion =P (Spoon Hybrid)
If you are worried about sufficient grounding...use the mounting holes for the power steering, and ground directly to the head and the frame
Old Feb 11, 2003 | 05:25 PM
Kid1320's Avatar
hahah after someone told me mine was wrong then i changed it to the "correct" location.
that answer would work for me.. thanks
Old Feb 11, 2003 | 06:19 PM
Jet Phi's Avatar
yea bro . . . the first picture is right
Old Feb 11, 2003 | 07:04 PM
Patrick's Avatar
Default Re: ground wire confusion =P (- [ b16a2 ] -)
What kinda super crack is the guy with the DA smokin?
Yeah you shoulda taken a pic of you stickin the ground wire up your nose, with a caption that says "Here?". LOL I would busted up laughin.
Old Feb 11, 2003 | 08:00 PM
wHOAlly's Avatar
Default Re: ground wire confusion =P (gsr_vx_hatch)
yes, u need to ground your valve cover beacause then ur sp00n cams wont work properly if u dont
Old Feb 11, 2003 | 08:29 PM
WOLFPACK's Avatar
Correct Grounds the through the valve cover bolt to the head...
Old Feb 11, 2003 | 09:58 PM
B2FiNiTY's Avatar
The one on the right is for the JDM throttle cable.
Old Feb 11, 2003 | 10:18 PM
BenB's Avatar
Default Re: ground wire confusion =P (B2FiNiTY)
This is the right answer. The wired grouned in the car with the red engine bay is for the JDM throttle cable. Since everything on the JDM cars is on the other side, the throttle cable comes across and mounts to this point.
The ground is in the correct location in the car with the blue engine bay.
ezcape
May 10, 2011 10:52 PM
civicgsr499
Jun 5, 2009 11:41 AM
chatman_55
Mar 17, 2009 08:05 PM
cr00klyn718
Sep 30, 2002 02:52 PM
Rdriver
Jan 15, 2002 07:03 AM
