85 CRX Si Motor Mounts
Old Feb 11, 2003 | 02:04 PM
1985CRXSiSoCali's Avatar
Default 85 CRX Si Motor Mounts
hello i have a 85 CRX Si and i was woundering if anyone knows a place to get cheap motor mounts for a b18?
Old Feb 11, 2003 | 04:41 PM
Boman's Avatar
Default Re: 85 CRX Si Motor Mounts (1985CRXSiSoCali)
Be prepared to spend ALOT of money, and wreck all handling capabilities of the
1G CRX.
Try www.hasport.com
j
Old Feb 11, 2003 | 06:11 PM
E-Town4229's Avatar
Default Re: 85 CRX Si Motor Mounts (Boman)
yes go to hasports site they have what you need. but contrary to what boman thinks your car will handle fine even with the added weight. good luck.
-Roger
Old Feb 11, 2003 | 06:13 PM
Losrocket_'s Avatar
1G CRX.
The handling of the vehicle isnt going to be much different with a B18. Its going to handle the same and ride the same. The only major thing youll notice is torque steer Although a B18 weighs substantially more than the stock D15, the handling will be exactly the same.
I dont know the cheapest place to buy the mounts but i do know HASports the way to go. There '84-87 B series kit is one of the most expensive mount kits they have though so no matter where you get them from theyre going to be somewhat expensive.
Old Feb 11, 2003 | 06:15 PM
Mugen Dom's Avatar
Default Re: 85 CRX Si Motor Mounts (E-Town4229)
-Roger
roger is correct but be prepared to walk away walking funny from being *** raped by hasport for the mounts......u can swap over integra front tosion bars to help with the added wieght also
Old Feb 11, 2003 | 08:45 PM
Vandemar's Avatar
What other parts are needed for this swap? I noticed Hasport has axles listed for $250, is there a cheaper source?
BTW, I'm planning on a B16 in an 87 CRX Si, if that matters.
Old Feb 11, 2003 | 08:49 PM
Mugen Dom's Avatar
Default Re: 85 CRX Si Motor Mounts (Vandemar)
uhhhh how mcuh do u pay for axles at pepboys or whereever call hasport and ask them if theres a warranty if there is they are priced pretty well if u think about it axles from pepboys and other places arent cheap and honda oem ones are $$$$ i duno about doin a b series in my 1st gen id be cool and all but the d16a1 for now will be fine and less expensive
Old Feb 11, 2003 | 09:02 PM
Qfactor's Avatar
try place racing engine mounts they are about 200 cheaper than hasport, use the 87-89 integra axles you will also need the front knuckle assembly along with the somewhat bigger rotors, you might want to add thicker torsion bars to handle the extra weight. for the shifter linkage you can either go with your stock unit and modify or use an integra and modify too. wiring is not bad since you have an SI. I've done two 85's dx's with b16a's and my 85 hf H22. if you need more info IM or email me.
Old Feb 11, 2003 | 11:29 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: 85 CRX Si Motor Mounts (Qfactor)
H22(3)s are so ******* useless.
popeye10,000rpm
Aug 28, 2009 08:57 PM
killabs
Apr 3, 2009 09:46 PM
the_rex
Jan 30, 2008 04:33 PM
Dj Lotte
Nov 29, 2002 08:07 AM
russian_racer
Sep 19, 2002 08:53 PM
