Cannot get out of park! (Auto)
Old Feb 11, 2003 | 01:06 PM
greaselightning's Avatar
Default Cannot get out of park! (Auto)
People have said it may be the shift lock solenoid. I cannot get out of park without using the shift lock release under the center console. That 'click' that I usually hear when I depress the brake pedal is no longer there. I have checked all fuses....what should I do??
'99 LX-V6
Old Feb 11, 2003 | 01:27 PM
cyrixvsp2's Avatar
Default Re: Cannot get out of park! (greaselightning)
this was covered. welcome to the board and please read the guidelines. if you do a search you could easily find your answer.
being a 99 my advice would be to take it to a dealer. it sounds like the switch for the brake pedal went bad. There is a switch so when you press hte brake pedal it will allow you to shift out of park. That switch probably went bad. I don't know how hard it is to change so it's best to take it to a dealer so you don't mess anything up.
Old Feb 11, 2003 | 02:13 PM
iam7head's Avatar
Default Re: Cannot get out of park! (cyrixvsp2)
open up the cover and see if anything is stuck on the assembly..
Old Feb 11, 2003 | 06:59 PM
carolinaACCORD's Avatar
Default Re: Cannot get out of park! (iam7head)
it is your brake switch signal.
do your brake lights work?
no-fix your brake switch circuit
yes-measure voltage of the brake switch wire, should read battery voltage.
if there is battery voltage, check for loose connectors at the ECU or substitute the ECU with another one abd recheck or inspect the brake switch circuit.
it there isnt battery voltage, trace back and repair the open in the wire.
Old Feb 12, 2003 | 03:22 AM
bill-71SS's Avatar
if your brake lites are out also, replace the switch on the pedal.
Old Feb 12, 2003 | 12:21 PM
Default Re: Cannot get out of park! (bill-71SS)
Thanks guys...yeah I did read the previous posts...but they didn't help too much and were old. I am gonna mess with it today with my friend. I think it is by the brake pedal where the problem is, like you said the brake switch down there....I'll let you know.
Old Feb 12, 2003 | 01:17 PM
95sihb's Avatar
I'm not 100% sure if you can get the car out of park the car moves. the reason I ask is because a few years back i was driving a 93 toyota camry auto the front motor mount( torque mount) broke , I could not shift from park to any gear..... and the car would not move even if i used the key to release the shifter.
babybreese
Aug 16, 2017 12:33 PM
jdmh22eg2
Transmission & Drivetrain
Dec 1, 2012 08:29 AM
91efbluehatch
Jan 30, 2011 12:56 PM
timrichter9
Feb 25, 2010 04:11 PM
NYCsnowman
Jan 24, 2006 01:13 PM
