what part is this on my intake sk2 manifold?
Old Feb 11, 2003 | 12:48 PM
Rob Dizzle's Avatar
Default what part is this on my intake sk2 manifold?
what is the part that is on the intake manifold. it is 90* bend, it is right below where the valve cover breather is. it is the red valve next to the injector
i have the skunk2 intake manifold, and I did not install it. It would be very helpful to know what it is called. I could not find the part on my acura parts cdrom program.
i thought it was the pcv valve. but I looked in my helms, and it shows that it is on the crank case breather box.
[Modified by Bob-DC2, 4:32 PM 2/11/2003]
Old Feb 11, 2003 | 12:49 PM
sgT's Avatar
sgT
Default Re: what part is this on my intake sk2 manifold? (Bob-DC2)
that is the PCV. you need that.
its not on the catch tank
Old Feb 11, 2003 | 12:50 PM
Austin's Avatar
That's what it is...the itr and sk2 manifolds have the pcv valve mounted on the intake manifold as opposed to directly on top of the crank case breather box. If you have a newer helms you'll see it listed.
Austin
Old Feb 11, 2003 | 01:07 PM
Rob Dizzle's Avatar
Default Re: what part is this on my intake sk2 manifold? (Austin)
chris said it was pcv valve. but i forget what it was when I went to order it today.
part # of pcv valve is:
17130-PM6-G01 in case someone looks at this in the archives, this post will be somewhat helpful
thanks steve & austin
Old Feb 11, 2003 | 01:13 PM
Eva01's Avatar
Here's a diagram of where the PCV is. It's #7.
[Modified by Eva01, 10:15 PM 2/11/2003]
Old Feb 11, 2003 | 01:23 PM
sgT's Avatar
sgT
Default Re: what part is this on my intake sk2 manifold? (Eva01)
Wrong picture buddy.
Old Feb 11, 2003 | 02:11 PM
Leo's Avatar
Leo
Default Re: what part is this on my intake sk2 manifold? (sgT)
Should the PVC valve for a Type R be replaced at a certain time? What exactly does it do? Thanks
Old Feb 11, 2003 | 03:46 PM
IVANITR's Avatar
Default Re: what part is this on my intake sk2 manifold? (Cyborg Ninja)
What happens if you don't have a catch tank for that?
SnailSlowDelSol
Feb 21, 2016 09:26 PM
Nickabeans
Jun 11, 2014 02:34 PM
InvisableAzn
Apr 18, 2007 11:38 AM
2lobes1engine
May 12, 2004 07:56 PM
koco
Feb 16, 2003 02:37 PM
