Golden Eagle Mfg Titanium Fuel Rail Pics!!!
Old Feb 11, 2003 | 09:25 AM
MotorMatrix.com's Avatar
I am a bad person
Default Golden Eagle Mfg Titanium Fuel Rail Pics!!!
We just got in the new GE Mfg high flow fuel rail. Its a beautiful piece.Email if you need any further info or pricing. Mike@motormatrix.com
Modified by MotorMatrix.com at 1:43 AM 6/2/2003
Old Feb 11, 2003 | 09:43 AM
BROOD's Avatar
Default Re: Golden Eagle Mfg Titanium Fuel Rail Pics!!! (MotorMatrix.com)
The black rail is also very nice, the face is a flat black finish. I'm more than happy with it
Of course looks is only a small part of it
My only suggestion is that if you want (6, 8, or 10) AN fittings in and out of this rail, you better clearly specify that during your order.
[Modified by SLPR, 12:15 PM 2/11/2003]
Old Feb 11, 2003 | 09:56 AM
Smashback's Avatar
Default Re: Golden Eagle Mfg Titanium Fuel Rail Pics!!! (SLPR)
True, looks are only a part...I mainly bought the STR rail because my stock rail wasn't flowing anough fuel at under 300 HP
Old Feb 11, 2003 | 09:58 AM
alpha's Avatar
Once my block is done at GEM (got there yesterday) I am going to get one of these fuel rails.
Old Feb 11, 2003 | 06:03 PM
GRT's Avatar
GRT
who's going to drill them out for you?? hmmmm! I know. I'll let you guess
Old Feb 11, 2003 | 06:12 PM
BudaKai's Avatar
Default Re: Golden Eagle Mfg Titanium Fuel Rail Pics!!! (GRT)
You have to add the fuel bungs yourself? How much to get them with the bungs installed?
Old Feb 11, 2003 | 06:54 PM
Tinker219's Avatar
please elaborate...
Old Feb 11, 2003 | 07:47 PM
Smashback's Avatar
Default Re: Golden Eagle Mfg Titanium Fuel Rail Pics!!! (Tinker219)
All I can think is he thinks there are no injector bungs..? I dunno...if that's it, they're on the bottom.
Old Feb 11, 2003 | 07:58 PM
Tinker219's Avatar
Default Re: Golden Eagle Mfg Titanium Fuel Rail Pics!!! (Hatchblack)
I found it....they are trying to put 1600cc injectors into that rail, and they need to go larger...hence the drilling out...sounds like fun to me
Old Feb 11, 2003 | 08:20 PM
I am a bad person
the bungs are on botom and they need to be drilled out for 1600cc injectors. the catch is my partner chris "GRT" will be the one doing that since he does the fab work and engine building. there are you happy chris??? Chris does the engine building
Old Feb 11, 2003 | 10:22 PM
V-SPEC 1's Avatar
Only if you want those fittings with your order. You can purchase those seperately and in your local performance store. I got mine today and it came with plugs and if I want to keep my stock fuel setup I can do so. But i'm not, I'll be running -8 AN inlet, and -6 AN outlet.
Old Feb 12, 2003 | 06:46 AM
BROOD's Avatar
Default Re: Golden Eagle Mfg Titanium Fuel Rail Pics!!! (boostedb20vtec)
I was mearly making a suggestion...after a mistake of my rail being shipped with oem style fittings but asking for 6AN fittings. Simple mistake fixed by GEM with a later phone call. So with my 6AN fittings I also order a second rail with 8AN fittings. Yes it was incorrect to assume that I would get an AN fitting for inlet and an AN fitting for outlet. I am not using the oem fpr set-up. (now I wondering why I'm even explaining this)
I only posted originally so someone else doen't make the same assumption. It is still a great fuel rail and I'm very happy with it, Thanks GEM
But thanks for stating the obvious
Old Feb 12, 2003 | 05:01 PM
GRT's Avatar
GRT
and cars too!
Old Feb 14, 2003 | 09:50 PM
X-Mazda 3 Racer's Avatar
We do offer this service to anyone that wants it. The rails can be drilled and reamed to accept the larger GM style injector o-rings if you want, but what I do usually is get two of the OEM Honda orings and place them on the GM style injector top and this works fine! We can alter any product we offer for a nominal fee! Just let us know what you desire. These are the benefits of having the manufacturer work for you.
[Modified by GoldenEagleMfg.com, 7:16 PM 2/17/2003]
koolaid3246
May 7, 2007 05:18 PM
Wideopentuning
Welding / Fabrication
16
Sep 20, 2005 12:01 AM
4piston
Jul 25, 2005 04:28 PM
X-Mazda 3 Racer
Jan 24, 2003 09:58 AM
