Does Greddy injectors 720cc make low resistor injectors?
No love..
Ok, How about this question? At what injectors size do you then need a reisistor pack? I have a Greddy 720cc right now and someone told me they are low resistor injectors which requires no resistor pack.
I spoke with Greddy directly and they are saying the injectors are low impedence which is meant for additional injectors running only, NOT to replace OEM injectors. He also mentioned, it might not fit in the fuel rail. And yes, the injectors do fit in the STR fuel rail. I am confused.
If anything over 440cc, do they have to be saturated or peak and hold?
you can get larger saturated injectors from RC there prices are out rageous i think the larges most people carry in saturated bolt on injectors are 550cc
confirmed with Greddy again, they only make it with low impedence and peak and hold 720cc injectors. this is for the record. anyway, i will need a resistor box for sure!
Thanks guys.
Thanks guys.
