Rotating Tires Question
Old Feb 11, 2003 | 06:24 AM
crazy_ham's Avatar
Default Rotating Tires Question
Does it really matter where you get your tires rotated on? Would it be a big difference if you went to, like, Walmart to rotate on tires, or should you go to some autocenter to get it down by specialists? O, and also, how often should you rotate? Thanks.
Z
Old Feb 11, 2003 | 06:32 AM
2000blackgsr's Avatar
Default Re: Rotating Tires Question (crazy_ham)
walmart, or a place like that should be able to rotate your tires, but if you have low-pro tires i would recommend going somewhere else. you should rotate your tires every 5000 miles or so
Old Feb 11, 2003 | 07:17 AM
kommon_sense's Avatar
Default Re: Rotating Tires Question (96coupe)
you can rotate them yourself. It really doesn't matter unless you have directional tread on your tires. with directional tread, you can really only rotate front to back and vice versa. no side to side.
Old Feb 11, 2003 | 07:19 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Rotating Tires Question (kommon_sense)
rotating tires requires 5 minutes of your time. directional tires go front to back and all-seasons go front to back in an X-pattern. They don't actually remove tires from rims...at least when I worked at SAM's Club in the garage we didn't.
Old Feb 11, 2003 | 08:02 AM
crazy_ham's Avatar
Default Re: Rotating Tires Question (Archidictus)
Damn... so I could rotate my OWN tires?! Wouldn't that make my alignment funny or anything? I'll have to look into that..... Thanks fellas
Z
Old Feb 11, 2003 | 08:04 AM
BROOD's Avatar
No it won't mess up your alignment. It is as simple as changing a flat...just you are doing it four times. Depending on your tools/equipment 7-15 minutes tops.
Here is the intervals I use:
oil changes every 3K
tire rotation (front to back) every 6K
tire rotation and rebalance every 12K
[Modified by SLPR, 9:05 AM 2/11/2003]
Old Feb 11, 2003 | 08:22 AM
piscorpio's Avatar
Damn you're fast! Do you have a lift in your garage?
Old Feb 11, 2003 | 09:00 AM
clm's Avatar
clm
Z
It won't throw of your alignment, but if it pulls to either side, your tires could be going bad.
Old Feb 11, 2003 | 10:13 AM
BROOD's Avatar
Default Re: Rotating Tires Question (piscorpio)
Moderatly fast is a full tire rotation and re-balance. Tires leaving the ground and touching back down in 7 minutes.
Old Feb 11, 2003 | 10:24 AM
Perfectionist's Avatar
Yes you can do the rotation yourself. The hard part is you have to have two wheels in the air at a time, so be careful. Also, one word of advice... Use a torque wrench to tighten your lug nuts to 80 lb/ft. Your rotors will thank you. That's alo why I avoid chain tire stores.... air impact guns!!!
tootybaby
Wheels
Dec 20, 2009 10:28 PM
da9leo
Oct 17, 2008 12:44 PM
Green Bar
Jul 29, 2005 03:27 PM
