B e s t B a t t e r y ? ? ?
i wanna upgrade my battery for my 2000 integ.
i plan on having a sound system pushing over 1000 watts.
will an Optima battery fit with adjustment?
on on Optima website they said to take off some cover or something
and the battery might fit for a honda application...
any suggestions?
any suggestions?
If you have a 2gen integra it should fit. If you have a newer Integra you may want to look into Stinger. They make a dry cell that fits nicely in newer integras.
SVR also makes a battery that will fit with no modifications in most Honda s
i found out that the
SVR 50-12 fits with no mods...
thanks rcurley...
thanks rcurley...
thanks rcurley...
No problem...PM me with the price that you get it for if you do indeed buy it...I need one soon for my civic
thanks rcurley...
Voltage 12
Reserve Capacity 90
Amp Hour 55
CCA* 600
Max Amps 1800
Length 9.3"
Width 9.2"
Height 5.5"
Weight 38 lbs
MSRP $ 149.95
Wholesale Price $ 85.95
Optima battery are great. The red top cause it's a deep cycle battery. Will last a long time. You can leave your headligths on and come back in a few hours and still start up your car.
thanks rcurley...
thanks rcurley...
try optima
From: Do I look like Michael Bolton from Office Space,, MD, USA
SVR suks - i paid nearly $300 for mine.. & it went bad.. i had it sent back to SVR- cuz it was still covered under warranty... BUT SVR wouldn't replace it.... they suk-- that was $250+ down tha drain..
try optima
try optima
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL »</TD></TR><TR><TD CLASS="quote"><BLOCKQUOTE>quote:<HR>SV R also makes a battery that will fit with no modifications in most Honda s
thanks rcurley...
No problem...PM me with the price that you get it for if you do indeed buy it...I need one soon for my civic<HR></BLOCKQUOTE>http://www.wholesaleaudio.com/svr.html
Voltage 12
Reserve Capacity 90
Amp Hour 55
CCA* 600
Max Amps 1800
Length 9.3"
Width 9.2"
Height 5.5"
Weight 38 lbs
MSRP $ 149.95
back from the dead!!
how does the new Optima battery for imports stack up against the SVR i was
interested in?
thanks rcurley...
Voltage 12
Reserve Capacity 90
Amp Hour 55
CCA* 600
Max Amps 1800
Length 9.3"
Width 9.2"
Height 5.5"
Weight 38 lbs
MSRP $ 149.95
interested in?
Well according to the specs, it seems that both the stinger and optima yellow top (for hondas) are more expensive and have less CCA's and whatnot than the SVR.
I am gonna get an SVR one of these days, but thats a little bit farther down the list
B2FiNiTY
Oct 13, 2003 08:03 PM
