putting in pistons on a budget
Old Feb 10, 2003 | 10:33 PM
lilblacksol's Avatar
Default putting in pistons on a budget
I got some pr3's and i wanna put them in my c1 whats the best way to do it if you are a racer on a budget?
Old Feb 11, 2003 | 12:58 AM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: putting in pistons on a budget (lilblacksol)
Huh??
Old Feb 11, 2003 | 06:19 AM
TimoneX's Avatar
New User
Well you've still gotta take out your pistons & rods. Take em to a machine shop and have your pins pushed out of the GSR slugs and pressed into the PR3s. You'll need a cheapish ring compressor and rings if you don't have any to re-install.
Old Feb 11, 2003 | 08:48 AM
mattcxb18's Avatar
Default Re: putting in pistons on a budget (TimoneX)
Are ctr's alot better then pr3's in a gsr? What is the difference?(comp. & price)
Old Feb 11, 2003 | 09:11 AM
TimoneX's Avatar
New User
Default Re: putting in pistons on a budget (mattcxb18)
12:1CTR vs 11.4:1PR3 in a GSR. I think CTR pistons can be found for $250ish.
Old Feb 11, 2003 | 06:57 PM
mattcxb18's Avatar
How much are pr3 (b16) pistons and rings? Will they connect to gsr rods? What head gasket to get 11.4:1? Do the pr3 fit right in or do they need to be oversized?
Old Feb 11, 2003 | 09:14 PM
TimoneX's Avatar
New User
1) These can be had very cheaply on eBay or similar since people replace the stock pistons and the used OEM pistons have little value.
2) Yes.
3) Head gaskets were not specified so I used the stock 3 layer gasket for those compression numbers.
4) Huh?
Old Feb 11, 2003 | 09:22 PM
threatcon13's Avatar
New User
4) Huh?
i think he is referring to whether they need to be .25 over or not..and no they dont have to be. but if u have the money i would think its better to bore out and get the oversized ones.
94-integra-ls
Mar 23, 2008 09:19 AM
1fastEK9
May 11, 2007 09:14 AM
calib17a
Jun 3, 2004 12:23 PM
TIRENECK
Mar 17, 2003 11:33 PM
Cashflo
Jan 27, 2003 03:56 PM
