b16a for 90 crx
Old Feb 10, 2003 | 08:48 PM
Aquafina's Avatar
Default b16a for 90 crx
I am in talks to buy a B16A shortblock to drop into a 1990 CRX. The problem is that the CRX requires a cable tranny (right?) and the B16A uses a hydro tranny. Is it possible to use a cable tranny on an engine that came stock with a hydro tranny? I need an answer from someone who knows their stuff ASAP as I don't want this enginesold out from under me.
Old Feb 10, 2003 | 08:53 PM
sleeper4dr's Avatar
Default Re: b16a for 90 crx (SuperStreetRX7)
all b-series trannies can mount to all b-series blocks without any problems. the exception would be the 88-91 prelude motors.
but if you wanted to you could run an '01 ITR block and still use a B-series cable trans.
Old Feb 10, 2003 | 08:58 PM
Aquafina's Avatar
Default Re: b16a for 90 crx (sleeper4dr)
So I can use the B16A with a B16A tranny in an older 1990 CRX and not worry about cable or hydro?
Old Feb 10, 2003 | 09:02 PM
sleeper4dr's Avatar
since you have a 4th gen civic (88-91) you need a cable trans. what year B-series engine you have doesnt matter as far as the mating of the trans to the engine.
thats only one of your problems though. you are also going to need a pre-OBD (preferrably 1st gen JDM B16) ECU, distributor and injectors unless you want to do some rewiring so that you can run the B16s current computer which i assume is OBDI.
Old Feb 10, 2003 | 09:20 PM
YumVTEC's Avatar
what you are failing to realize is that not all b16a's have hydro trannies. the Civic SiR1 in Japan (88-91) has a pre-obd b16a with a cable tranny. that's the swap you need to put in your car. you can pick one up for around $1000-1200 for the whole swap including axles, ecu, etc...
Old Feb 11, 2003 | 03:55 PM
Aquafina's Avatar
Default Re: b16a for 90 crx (YumVTEC)
The B16A I am buying has a stock hydro, and I found a 90 B16A tranny which is cable so it will work.
Does a second gen. GSR tranny have a LSD?
Old Feb 11, 2003 | 06:28 PM
sleeper4dr's Avatar
no USDM GSRs came with LSD. only the JDM YS1 had the option of an LSD.
Old Feb 11, 2003 | 10:20 PM
jdmWONG's Avatar
if the b16a your buying has a stock hydro than chances are its not a obd0 b16, which means your gonna need a new dist, ecu,and injectors. on top of that you will still need axles, shiftlinkage, and a motor mount kit.
super trucker
Apr 19, 2009 05:22 AM
rjc89sir
Jul 26, 2005 02:45 PM
volcom40street
Jan 20, 2005 09:52 PM
Unknown Member
Jan 23, 2003 08:17 PM
