Need Some Help, my wheel weight fell off
put it this way, your wheel is going to get off balance whether you got the balance on or off.. if no shaking then you're fine until the next time you get them re-balanced - do it every 3000 miles
You are wrong, get it rebalanced or you suffer the consequences of irregular ware on the tire.
Tip: Avoid costco dude. Really? Bad experiance?
Denny, I took mine to Tire America down N. Bristol, seemed to do alright for me.
I took mine to the same America's Tire. They are great
Bit expensive but great.
really really bad experience. Check a thread made by surferX.
Glad I'm not the only one who went there.
I take my car to America Tires. They do a good job and they torque your tire!!! Just got it rebalanced and stuff. Plus they did it for free!!
to the America Tire in Lake Forest on Aspen!!
Rebalance it anyway. It is suggested that you rebalance at 6000-8000 miles. For those of you who say it doesnt affect anything!! Yeah right, it sure does! It prevents abnormal tire wear and for the guy who has 20K miles on his tires and hasnt balanced it, try rebalancing now and Im sure you would feel a difference.
Whoever balances your wheels should balance the wheels using the "Fingers." Its alot more precise than using your standard single stud (through the center) technique.
migs
[Modified by Migs, 5:27 PM 2/11/2003]
migs
maybe, maybe not i got 32,000 miles on my s-03's with plenty of tire spinning - theres still enough thread left for another 10-20K miles - if i didn't do burn outs with these tires, i would definately get 50K miles, i'm not sure at this point.., to help with wear, I cross mounted the tires at 30K
- before this i went through 2 sets of re010 with 15K on each set - i rotated every 6-7K miles and they were more worn on the inside...
put it this way, your wheel is going to get off balance whether you got the balance on or off.. if no shaking then you're fine until the next time you get them re-balanced - do it every 3000 milesSeems a bit excessive, isn't it?
i balance mine for free and whenever i want
. it doesn't change, i dont think it's neccessary to do it every 6k miles.
TrackSpeedRacing
Northern California (Sales)
Aug 25, 2007 07:51 AM
arren123
Jun 7, 2006 05:11 AM
