rota...15x7
I've been bugging Kim at Rota. He/She said they should be available in March. He will be emailing me once they are ready. I'll be sure to spread the word as soon as I receive notice. I want these wheels too.
ant
ant
are they going to be a "new" style(since every wheel is a knock off, Im not complaining) or are the going to make the same wheels avaible in 15x7, if they are then i am going to wait to order my wheels.
ant
ant
Wheels should be Slipstreams.
at that price, is it really worth the wait that to just buy kosei? the K1's have wider and i believe better offset as well. and quite frankly, there are several options from Borbet that are 15x7 for UNDER $100.
[Modified by Tyson, 8:24 PM 3/1/2003]
i dont really have any information on the borbet wheels. but machiii has the stern aguzze wheels with a 43 offset and they are 400 shipped. so they would be cheaper then rota.
i think i might just bite the bullet and get the aguzze wheels. but i would rather have a 45 offset...do you think that 2mm will be of any concern? i doubt it.
art, what issues do you forsee arising with the 15x7 43+ aguzze wheels? why would you need a 2mm spacer on an R?
If you go wider than a 205/50-15 r3so3, you'll rub the trailing arm in the rear. My 225/45-15 r3s03's still polish the arm a bit with a 3mm spacer. (this is with a 15X7 and 42mm offset).
Has anyone thought about notching (then welding in an arc-shaped filler plate) the trailing arm to make room for the tire for this kind of situation? Strength issue maybe?
[Modified by jg, 3:58 PM 3/9/2003]
timisyourfriend
Apr 30, 2007 04:34 PM
PatrickGSR94
48
Jan 13, 2003 08:00 AM
for finally making a 15x7
