Car running cold.
Old Feb 10, 2003 | 03:09 PM
Superhatch's Avatar
Default Car running cold.
After months of normal operation my sohc ZC is acting a bit weird. The temp guage will be fine if im driving hard, but then dips down about 1/2 way between cold and off if Im driving normal. At some points it is all the way cold.
Thermostat? Other ideas?
-Jake
Old Feb 10, 2003 | 03:15 PM
Vinceg99's Avatar
Default Re: Car running cold. (Superhatch)
I would say start with the simple things and replace the thermostat as you already said. Otherwise is your fan running all the time when the car is on?? I know that my GF's car overheated last winter cause her fan wasnt kicking on and I found out that the motor was fried so I went and picked one up and now the dang thing runs all the time I have been too lazy to check her fan switch but I know lately (especially how cold its been up here) her car hasnt been having the greatest heat either its still heat but not as hot as it use to be......
Old Feb 10, 2003 | 05:10 PM
slomofo's Avatar
GDD Member
Same problem with both of my Civics and Integra. Coolant temp Sensor. It only happened in the winter time for me though on the civics, integra did it year round.
Old Feb 10, 2003 | 05:35 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Most likely is a stuck open thermostat, sounds like exactly the problem I was having with my d16a6.
-Todd
Jreks
Aug 10, 2011 09:29 AM
dc2_dude
Oct 6, 2010 03:25 PM
simplypinoyy
Nov 23, 2008 06:18 PM
tianporn
Jun 18, 2005 07:22 PM
