Idle Air question please help???????
Old Feb 10, 2003 | 02:14 PM
TEGPOWER44's Avatar
Default Idle Air question please help???????
I swapped a GSR motor in my civic and its throwing code 14. I havent hooked up the idle air control valve yet because I dont know where it goes. Does it go from the manifold to the black evap thingy??? Please help...(I tried searching)
Old Feb 10, 2003 | 02:27 PM
BlazeInEk's Avatar
Default Re: Idle Air question please help??????? (TEGPOWER44)
The IAC Valve is on the intake. The wires from the plug go to the ecu. If you swapped in a 99+ motor and are using a 96+ harness/ecu then you have to change the wires in the ecu. If this is the case let me know and I will scan and post the diagrams for you.
Old Feb 10, 2003 | 02:33 PM
TEGPOWER44's Avatar
Default Re: Idle Air question please help??????? (BlazeInEk)
I swapped a 95 gsr motor in my 98 civic with civic wiring harness. Where exactly would the wires go??? I am using a OBD1 P28 ECU. Just tell me what color the wires are and I will figure out the rest. Thanks
Nisif
Oct 3, 2014 02:39 AM
turbodelsolb16a2
May 4, 2010 02:50 AM
jdm civic 2000
May 21, 2002 06:08 PM
