Idle Air question please help???????
I swapped a GSR motor in my civic and its throwing code 14. I havent hooked up the idle air control valve yet because I dont know where it goes. Does it go from the manifold to the black evap thingy??? Please help...(I tried searching)
Re: Idle Air question please help??????? (TEGPOWER44)
The IAC Valve is on the intake. The wires from the plug go to the ecu. If you swapped in a 99+ motor and are using a 96+ harness/ecu then you have to change the wires in the ecu. If this is the case let me know and I will scan and post the diagrams for you.
Re: Idle Air question please help??????? (BlazeInEk)
I swapped a 95 gsr motor in my 98 civic with civic wiring harness. Where exactly would the wires go??? I am using a OBD1 P28 ECU. Just tell me what color the wires are and I will figure out the rest. Thanks
