running rich at idle helpppppppppppppp!!!!!!
Old Feb 10, 2003 | 01:52 PM
khcivic's Avatar
Default running rich at idle helpppppppppppppp!!!!!!
i have a problm with running rich at idle. i usually get 330 miles to a full tank of gas with my b16. but i runs really rich at idle. like 12.5 to 1 air/fuel. i hooked it up to a machine at college.im going to go tomarow and test my 02 senor and others also and change plugs to see if that helps. any help i would love thanks.
Old Feb 10, 2003 | 02:12 PM
tinkerbell's Avatar
Default Re: running rich at idle helpppppppppppppp!!!!!! (khcivic)
are you getting any codes?
t..
Old Feb 10, 2003 | 02:19 PM
khcivic's Avatar
Default Re: running rich at idle helpppppppppppppp!!!!!! (tinkerbell)
no codes at all
Old Feb 10, 2003 | 02:28 PM
skunked's Avatar
Are you running a stock ECU program? If not it could just be the program. I have to take out 10% at idle with my Skunkworks Race program......
Old Feb 10, 2003 | 05:50 PM
khcivic's Avatar
Default Re: running rich at idle helpppppppppppppp!!!!!! (skunked)
i do have a endyn program but this problem just started about a month ago and ive had the ecu for about a year now
Old Feb 10, 2003 | 10:41 PM
TimoneX's Avatar
New User
I don't think it's a problem. Every program I've run including stock has my car rich at idle. I just subtract fuel via the Vafc. Smoothes out the idle with the Crower cams.
Old Feb 11, 2003 | 02:51 AM
khcivic's Avatar
Default Re: running rich at idle helpppppppppppppp!!!!!! (TimoneX)
but it shouldnt run that rich at idle with it warm should it.
Old Feb 11, 2003 | 06:06 AM
TimoneX's Avatar
New User
Mine certainly does, without I don't remove a bunch of fuel down low.
Old Feb 11, 2003 | 01:43 PM
tinkerbell's Avatar
what did the O2 sensor test show?
how is your ECT sensor function?
it should run in closed loop at stoic at idle.
unless your program has no closed loop...
t..
Old Feb 11, 2003 | 06:28 PM
khcivic's Avatar
ect? i didnt get to test my my o2 senor maybe wensday. pulled plugs shows running rich a little. at idle my a/f meter should cycle back and forth right when it is completly warm. but mine stays about 3 bars in the rich.
Old Feb 11, 2003 | 06:37 PM
tinkerbell's Avatar
Engne Coolant Temprature sensor.
it tells teh engine it is warm. (it doenst tell you gauge anything though)
a malfunction of hte ECT will cause the rich situation that you describe.
search for "ECT" in the archives for info, there is HEAPS,
t..
ncsi
Jan 3, 2012 03:08 PM
turbotime
Jun 22, 2006 04:43 PM
omahaturbocivic
Mar 6, 2003 10:02 PM
echo999
Jan 28, 2003 12:37 PM
