What causes the drive belts to squeal?
your alternator belt is not tightned enough. Make sure you get the right size and have enough room to tight it more. Do not get something too small and squeeze it in cause that'll break the belt in couple months.
now the opposite..what causes the drive belts to whine..mine (not sure which but think the power steering belt) whines at idle and with the engine when reved...i hear it more in the car then out the car though... to tight i assume? belt dressing doesnt do jack for them...thanks
if so, it might not be your belt, it may be the power steering pump making noise...seals and bearings can wear out in the pump causing it to make that whining sound.....just like Ford's do, they whine like hell....
lankan-balla
Mar 8, 2013 01:02 PM
MeanGreenEG9
Apr 9, 2003 07:38 PM
