which type clutch to use for street/strip?
Old Feb 10, 2003 | 11:00 AM
NeoGSR's Avatar
Default which type clutch to use for street/strip?
i want to upgrade my clutch and flywheel but still want smooth engagement.....i drive this car daily and need to be able to feather the clutch in traffic and **** like that....i just want something better than stock but not too agressive....just a step higher...I go to the track on weekends no more than once a month so it really isn't too important for that type of use
I will be installing a ITR LSD tranny at the same time....if that makes any difference
Thanks for any input!
[Modified by NeoGSR, 2:02 PM 2/10/2003]
Old Feb 10, 2003 | 11:08 AM
RedGSR's Avatar
Default Re: which type clutch to use for street/strip? (NeoGSR)
ITR clutch
Old Feb 10, 2003 | 11:16 AM
EL Vap133's Avatar
ACT street/strip is perfect....
NeoGSR's Avatar
Default Re: which type clutch to use for street/strip? (RedGSR)
would the ITR have any advantage over my stock GSR clutch...i'm not sure what the difference is....
thanks again
[Modified by NeoGSR, 2:17 PM 2/10/2003]
Old Feb 10, 2003 | 11:35 AM
SIK IN DA HED's Avatar
New User
Default Re: which type clutch to use for street/strip? (Vap133)
try an ACT heavy duty 6puck.
Old Feb 10, 2003 | 11:43 AM
threatcon13's Avatar
New User
Default Re: which type clutch to use for street/strip? (dlplayboy)
clutchmasters stage 4
Old Feb 10, 2003 | 11:58 AM
Lewie's Avatar
I'm here for the gangbang!
Default Re: which type clutch to use for street/strip? (Threatcon13)
look at the act clutches
Old Feb 10, 2003 | 12:13 PM
Eva01's Avatar
Default Re: which type clutch to use for street/strip? (lewie4)
I have the exedy organic clutch and am very satisfied with it. Stock pedal feel, 32% more clamping force, and great price. Try clutchcityonline.com for good prices. Definately put in a lightened flywheel while your at it...
[Modified by Eva01, 9:14 PM 2/10/2003]
Old Feb 10, 2003 | 02:37 PM
lsteggy's Avatar
lol i say go for 5
Old Feb 10, 2003 | 02:45 PM
gsrvx's Avatar
New User
Old Feb 10, 2003 | 03:22 PM
NeoGSR's Avatar
sure buddy
Old Feb 10, 2003 | 03:26 PM
NeoGSR's Avatar
Default Re: which type clutch to use for street/strip? (Eva01)
that web site is full of viruses, my virus scan keeps catching it
Old Feb 10, 2003 | 03:28 PM
gsrvx's Avatar
New User
sure buddy
Well...upon reading his post...he'd probably wanna go with an act street/strip application. Though a cm stage 4 is streetable also imo.
-Rod
Old Feb 10, 2003 | 03:42 PM
allmotorls95's Avatar
Default Re: which type clutch to use for street/strip? (RK)
act strip stip...set up is the way to go...i think its hdss..or something like that..
Old Feb 10, 2003 | 04:45 PM
IntegCutie82's Avatar
I would have to agree on that ACT clutch.
Old Feb 10, 2003 | 04:52 PM
GSRaCeRbOI's Avatar
Default Re: which type clutch to use for street/strip? (IntegCutie82)
I had an ACT put in when it was time to replace my stock clutch.. put it in at about 88 or 89K worked great up until my accident a few weeks ago...
Old Feb 10, 2003 | 05:55 PM
97hb's Avatar
ACT HDSS feels just like stock, and can hold my 75 shot
Old Feb 10, 2003 | 06:15 PM
NeoGSR's Avatar
Default Re: which type clutch to use for street/strip? (97hb)
i read up on that one and like what i saw....
can i buy just a disc and get an improvement, or do i have to go with the pressure plate and disc to get any significant improvement?
Old Feb 10, 2003 | 07:15 PM
97hb's Avatar
My pressure plate had grooves in it so I just replaced it with the heavy duty one. Feels just like stock . You can probably go with the disk but I would get the whole kit because it comes with pp, disk, t/b, and pilot bearing. I just took my flywheel to a machine shop and they resurfaced it for $30. Don't forget the high temp grease for the shaft, huh huh he said shaft
Old Feb 10, 2003 | 07:22 PM
TeamTooQuick's Avatar
Im using clutch masters Stage 3 clutch and lovin it....
Old Feb 10, 2003 | 08:20 PM
EvilIntegrationLS's Avatar
Default Re: which type clutch to use for street/strip? (TeamTooQuick)
yea, i just ordered off an ACT streetlite flywheel to go with my ACT HDSS clutch i got for xmas, and i'm putting it all in when the flywheel gets here. definetly looking forward to that, but not the break in period.
Old Feb 10, 2003 | 09:04 PM
HmgLauj69's Avatar
ACT 4 punk disc with rings and plus heavy duty plate.....is good to go....soft as stock but grab good as hell.....my fren has a set of them in his integ ...if not then go with ACT street set up...
BOOCKER
Jan 22, 2008 08:48 AM
PYMUGENITR
Sep 19, 2004 03:52 PM
Naturally Aspirated
18
Aug 4, 2004 05:26 AM
Audio28
Jan 11, 2004 03:18 AM
RiceCarDriver
Jan 29, 2002 08:10 AM
