Air/fuel Meter
Old Feb 10, 2003 | 07:25 AM
ph0en1x's Avatar
Default Air/fuel Meter
I Have a non turbo 98 LS Integraand I am staring to do some mods and playing with my timing, but I wanted to know could running an Air/Fuel Meter With out a Turbo be BENIFICIAL FOR ME TO RUN IT?
Old Feb 10, 2003 | 09:08 AM
neo1z's Avatar
Default Re: Air/fuel Meter (ph0en1x)
what kind of mods do you have, and why are you playing with your timing? You dont need a turbo to benefit from an air/fuel gauge...they are mighty helpful in tuning....but if youre talking i/h/e then no, no need for it.
Old Feb 10, 2003 | 09:47 AM
TimoneX's Avatar
New User
Default Re: Air/fuel Meter (neo1z)
Don't bother with the el cheapo autometer A/F gauge either. It's not worth the time to install. Greddy, A'pexi, Halmeter...etc make good gauges/systems.
Old Feb 10, 2003 | 10:44 AM
ph0en1x's Avatar
All I have form now is an intake, and I have an exhaust but it's not on yet. But it's just the beginning, of my mods I am doing things slowly but things are getting done.
Old Feb 10, 2003 | 12:36 PM
TimoneX's Avatar
New User
Ya gots ta start somewhere. Good luck bro.
Old Feb 10, 2003 | 12:39 PM
Trac226's Avatar
Default Re: Air/fuel Meter (TimoneX)
Since you are just starting out, don't even bother with it. Plan out what your goals are first and if you get serious about tuning, look into a wideband o2 sensor.
Old Feb 10, 2003 | 12:46 PM
Fuuma0083's Avatar
Default Re: Air/fuel Meter (Trac226)
Old Feb 10, 2003 | 12:49 PM
jaymar88's Avatar
Default Re: Air/fuel Meter (Fuuma0083)
My Autometer AF gague makes for a neat little flashing light. Really a dummy light. The stock o2 sensor isn't fast enough to make an accurate reading. I'd save up and invest in a wideband if you're looking to tune your A/F ratio.
Old Feb 10, 2003 | 12:57 PM
threatcon13's Avatar
New User
even those are not accurate for shxt when it comes to air/fuel accuracy. they just give you an indication of whether youre running rich or lean. u'd have to have someone tune w/ wideband. DEFINITELY no need w/ i/he.
Old Feb 10, 2003 | 01:14 PM
TimoneX's Avatar
New User
Default Re: Air/fuel Meter (Threatcon13)
While I would agree with your assesment about the need(or lack of) for an A/F gauge with those mods. I've compared my Greddy gauge to a wideband graph and found it to be spot on accurate. I've seen others attest to the accuracy of A'pexi & Halmeter, hence my comment, though I have no personal experience with A'pexi or Halmeter gauges w/ an Acura. I adjusted my Vafc while referencing my Greddy A/F gauge. When I later had the car dyno'd the only changes made to the Vafc were right at the x-over point, which BTW was changed while tuning.
spooniq
Honda S2000
Jan 24, 2006 05:01 AM
RACEPAK
Jul 27, 2004 04:24 PM
SOHC50shot
10
Mar 17, 2004 04:35 PM
GripFactoR
13
Sep 23, 2002 04:03 AM
Turbohatch
Dec 15, 2001 12:21 PM
