this is a good setup
Old Feb 10, 2003 | 07:12 AM
sshaikh01's Avatar
Default this is a good setup
Have anyone ever tried to take a gsr block and put a b16 head on it.
Or wise versa.
any advantegas to this???
Old Feb 10, 2003 | 08:06 AM
4g4me's Avatar
Default Re: this is a good setup (sshaikh01)
well, if you do a search, you will see that the gsr head has slightly smaller combustion chambers, therefore you will sacrafice some compression.
If you use the ITR pistons, with the pr3(b16) head you can make a "poor mans ITR"
The only real advantage of the B16 head is the fact that a type r manifold will bolt right on, where as modification is needed for the gsr to accept that mani.
if you dont have the parts lying around, dont waste your time, with the head design of the pr3 and the lack of compression, that 1.8 will be torqueless.
-great turbo setup, high flow and you can squeeze a little more PSI with the 9.7 or so compression.
Thei WILL turn into a gsr vs B16 head thread, dear god is there arent 1000's of them already.
90B16aCRXsi
43
Jul 30, 2008 08:50 PM
L33TsAbabyEater
Sep 11, 2006 06:53 PM
maziospzza
Dec 2, 2004 12:33 AM
EFin' Kyle
Jul 26, 2004 10:09 PM
ajchen
Nov 25, 2002 07:12 AM
