It's alive...... again.
Old Feb 10, 2003 | 01:54 AM
Ausmith's Avatar
Default It's alive...... again.
My motor came to life last night. This is the second time I've built this motor as a winter project. I wasn't concerned about the motor itself, rather the wire harness. On my quest for simplicity (read: "lighter weight") I gutted every wire harness in the car. The result was roughly the removal of 10lbs (wires, brackets, connectors). I ended up only needing 3 fuses
So anyway, I finshed the wiring in my aluminum dash and I thought I would give it a shot to see if it would fire. I was all nervous that I had fugged something up in the ignition panel wiring.
I flipped the switch, fuel pump primes, vafc comes on. I cycled it one more time and went to look for fuel leaks. No problems, a solid 38psi on the guage. I hit the button. It turned 5 times and then lit up!!! I had to run around front and hold the TB open a little bit, otherwise it wouldn't idle (Toda B's kick ***!)
Here's the specs on the motor:
94 B18C1
Block
-complete balance, blueprint (King Motorsports)
-JDM ITR pistons (.25 over)
-Mugen oil pan
-New seals, bearings
-Polished crank
Head
-Chadzilla port job (King Motorsports)
-Stock head gasket
-Milled .013"
-3 angle valve job
-ITR valves
-Portflow retainers
-Toda valve springs
-Toda B's
-Toda Cam gears
-Toda timing blet
-Skunk manifold (port matched)
-Bored ITR throttle body
-250cc Honda injectors
Misc
-JDM DC header
-3" AEM
Some pics. I'm going to post a video with sound pretty soon
[Modified by Ausmith, 10:57 AM 2/10/2003]
Old Feb 10, 2003 | 02:39 AM
JoshuaVTEC's Avatar
Default Re: It's alive...... again. (Ausmith)
WOW nice work!
Old Feb 10, 2003 | 02:44 AM
Wannab16a's Avatar
I'm impressed!Great yob man!
Old Feb 10, 2003 | 02:50 AM
LHC's Avatar
LHC
awesome work mang!
Old Feb 10, 2003 | 02:59 AM
slowman's Avatar
I took way too long
Default Re: It's alive...... again. (spoonedcivicG4)
Whoa!! That thing should SCREAM!
video!!!! video!!!!
Old Feb 10, 2003 | 03:39 AM
egNYC's Avatar
very nice... clean
Old Feb 10, 2003 | 04:05 AM
00MRSi's Avatar
Default Re: It's alive...... again. (egNYC)
Clayton, nice work.. You taking the hatch to the EXPO to roll aaRR's?
Old Feb 10, 2003 | 04:21 AM
Civichatch972's Avatar
mmmmmmmmmmmmm nice!!!!!!!!!!!!
Old Feb 10, 2003 | 04:22 AM
Ausmith's Avatar
Default Re: It's alive...... again. (00MRSi)
Nah, I'm taking the Arrr to roll Arrr's and hatches
Old Feb 10, 2003 | 05:21 AM
00MRSi's Avatar
ROFLMAO!! Sounds good.. Looking forward to meeting you..
Old Feb 10, 2003 | 06:07 AM
hybrider's Avatar
lookin good
Old Feb 10, 2003 | 06:11 AM
White Lightnin's Avatar
Default Re: It's alive...... again. (hybrider93)
Sparkling clean engine bay. Wish I had the dough to build my engine.
Old Feb 10, 2003 | 06:23 AM
civicmandx94's Avatar
Default Re: It's alive...... again. (White Lightnin)
Nice job, that should move. Just wondering what brand of header are you using?
Old Feb 10, 2003 | 06:43 AM
owen_the_soyboy's Avatar
Default Re: It's alive...... again. (civicmandx94)
Old Feb 10, 2003 | 06:59 AM
The G2 Racer's Avatar
That's a JDM DC header. Says so in his post.
Looks sweet, should haul some ***.
Old Feb 10, 2003 | 07:09 AM
NiiS's Avatar
Post some timeslips(or predicted timeslips), I have a very similar set-up. Looks great though.
BTW: that bottom end rips, I love the compression, gets you to the powerband alot quicker
Old Feb 10, 2003 | 07:36 AM
EJ8man's Avatar
Default Re: It's alive...... again. (sinister)
Hot damn that is badass! Please hurry up on those videos pleeease.
Old Feb 10, 2003 | 07:46 AM
ImportechPerformance's Avatar
Default Re: It's alive...... again. (EJ8man)
i want to make hot monkey love with your engine bay!!!!!!!!
So clean its sickening!
Old Feb 10, 2003 | 07:51 AM
miskone's Avatar
that's one clean engine bay good job. show those V8's what honda is about.
Old Feb 10, 2003 | 07:52 AM
pennies_hatchie's Avatar
Default Re: It's alive...... again. (TheRedSkoolingBus)
sweet god...
great job
i see that you're also in WI...
i was thinking about doing the same type of mod to my engine this summer, maybe you could help me do the same to mines
[Modified by pennies_hatchie, 10:53 AM 2/10/2003]
Old Feb 10, 2003 | 08:23 AM
madtownhonda's Avatar
Default Re: It's alive...... again. (pennies_hatchie)
Looks clean!
Old Feb 10, 2003 | 08:53 AM
Buckshot's Avatar
Default Re: It's alive...... again. (madtownhonda)
that is one shiney header
oh yea nice set-up btw
Old Feb 10, 2003 | 08:58 AM
ITRinEJ1's Avatar
Default Re: It's alive...... again. (Buckshot)
clayton = balla
now maybe i'll have some competition at gingerwoman :cough: :cough:
Old Feb 10, 2003 | 09:36 AM
boomslang's Avatar
Default Re: It's alive...... again. (ITRinEJ1)
Sweet!
Old Feb 10, 2003 | 09:40 AM
iH8RICERZ's Avatar
Default Re: It's alive...... again. (boomslang)
wow, now thats sexy!
