how fast will i be on slicks if 13.976 on street tires?
Old Feb 9, 2003 | 11:25 PM
ALLMOTOR18's Avatar
Default how fast will i be on slicks if 13.976 on street tires?
here is the breakdown:
60' - 2.254
330' - 6.043
1/8 - 9.117 @ 80.32
1000' - 11.746
1/4 - 13.976 @ 101.04
Thanks in advance..
Old Feb 9, 2003 | 11:37 PM
DLB1994's Avatar
Default Re: how fast will i be on slicks if 13.976 on street tires? (gsrtyper)
13.5-13.30's
with a 1.9-1.8 60 foots
Old Feb 10, 2003 | 12:07 AM
ExospeedAMcrx's Avatar
with a 2.2 60ft. you can improve to a 1.8-1.9 60ft which will drop your 1/4 mile times by .4-.6 depending on your setup.. all motor or turbo. So you can drop your 1/4 mile time down to low 13 to mid 13.s
Old Feb 10, 2003 | 01:06 AM
Kwuaymaikrup's Avatar
Default Re: how fast will i be on slicks if 13.976 on street tires? (exospeedAMcrx)
I think maybe a little more even. A buddy of mine picked up .9 when switching to slicks. Not only did his 60ft. improve but everywhere else did as well. He was struggling with traction through the first 3 gears on street tires but after the slicks he hooked up. Just my .02 though. I think it varies for everyone. Good luck.
Ryan
Old Feb 10, 2003 | 01:18 AM
simple4012's Avatar
New User
Default Re: how fast will i be on slicks if 13.976 on street tires? (Kwuaymaikrup)
strong MPH. like a 13.2-13.4 id say.
Old Feb 10, 2003 | 02:02 AM
H25's Avatar
H25
i drove a car i built with a type r motor and ran 13.1@108mph on street tires with a 2.1 60 foot. i went to another track on slicks and ran 12.5@109mph with only a 1.7 60 foot. we lightened up the car with fiberglass doors and hatch. went back and ran 12.1@109mph on the same slicks. it all depends on your setup. and how bad your traction issues are to begin. with and how well you drive on slicks after. on average i would say about 6 tenths of a second. same setup radial to slicks.
Old Feb 10, 2003 | 03:11 AM
AussieK24's Avatar
Default Re: how fast will i be on slicks if 13.976 on street tires? (LuckyRacing)
Put me down for a 13.4 to 13.6
Old Feb 10, 2003 | 10:04 AM
MikeySpec's Avatar
Default Re: how fast will i be on slicks if 13.976 on street tires? (b16a4me)
I've done 13.40's on 97-98 shitty traps in a gsr hatchie.Hope that helps?Oh yah...1.8 60's all day long on 22.8X15's
Mikey
Old Feb 10, 2003 | 10:07 AM
ALLMOTOR18's Avatar
.. thanks guys..
.. how much would you guys say a 95 GSR without back seats, spare and jack weighs?.. thats the weight i have been running..
thanks..
Old Jul 20, 2003 | 05:50 PM
Fuster_Cluck's Avatar
Default Re: how fast will i be on slicks if 13.976 on street tires? (ALLMOTOR18)
I may have to get a set for dragin'
2.2 down to 1's sounds good
I think my 60' times were 2.3 - 2.4
Old Jul 20, 2003 | 06:40 PM
SlicksMH's Avatar
All I can say is when you go to slicks, you are going to say ( WOW ) why didn't I go to slicks along time ago. I have seen racers on M&H's, and drop 1/2 sec. John@M&H
Old Jul 20, 2003 | 09:28 PM
cleanEG's Avatar
Default Re: how fast will i be on slicks if 13.976 on street tires? (SlicksMH)
I definately need some slicks.....any suggestions on the size for a 2200lb civic with 200whp NA...was thinking about 22x8x13...thanks!
Old Jul 20, 2003 | 10:10 PM
blaaa's Avatar
im going to guess a 13.2 as your best
Old Jul 20, 2003 | 11:11 PM
SlicksMH's Avatar
Default Re: how fast will i be on slicks if 13.976 on street tires? (cleanEG)
Yes the 8/22-13 or the 9/22-13 now we have a new one coming out, and I am still waaaaaaiting for it is the 8/23-13. John@M&H
Old Jul 21, 2003 | 09:51 AM
ALLMOTOR18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlicksMH &raquo;</TD></TR><TR><TD CLASS="quote">Yes the 8/22-13 or the 9/22-13 now we have a new one coming out, and I am still waaaaaaiting for it is the 8/23-13. John@M&H </TD></TR></TABLE>
what sizes do you recommed in 15" using GSR tranny and making 195 whp?
Old Jul 21, 2003 | 10:40 AM
SlicksMH's Avatar
Hay (ALLMOTOR18):The only slick that would work for you in the M&H, would be the 7.5/23-15. Now if you can go to a 13" rim size, then I would go to the M&H 9/22-13 this would be the better slick for you. I hope this helps, Good Luck. John@M&H
Old Jul 21, 2003 | 12:44 PM
ALLMOTOR18's Avatar
will 195 whp be too much for the 7.5/23-15 slicks?
Thanks..
Old Jul 22, 2003 | 10:38 PM
SlicksMH's Avatar
If you use the 7.5/23-15 and your FD is 4.4 you will be running about 7200 rpm @ 110 mph is this what you need. John@M&H
Soda Popinski
Nov 21, 2005 07:24 AM
ALLMOTA_EF
Jan 29, 2004 04:37 PM
B_1_8_hatch
Nov 9, 2003 07:06 PM
Captn. Save A Hoe
Oct 27, 2003 12:50 AM
HX_Guy
Oct 11, 2001 07:25 AM
