d16y7??!?!?!?!
hey you guys, i want to put a d16y7 into my car (1993 del sol). i was wondering if you guys think its a good idea or not? i want this because of money issues......wuts a good price for this motor, including everything needed for the swap.....400-450? and if i do get this swap what kinda of potential am i looking at? i want to turbo the motor but can i get good #'s from this motor? alrigt thanks!
the Y7 is non-vtec, but you can swap a Y8 head on there later if you want.
it also has slightly lower compression than the Y8, which, I suppose, might be better for turbo-ing. check this thread for some info, and keep an eye out for Tom's thread about his beater build-up. there's also tons more SOHC threads out there. try the search.
https://honda-tech.com/zerothread?id=335078&page=1
I'm thinking you could save a couple hundred bucks and the hassle of pulling motors if you do a little mini-me swap (A Y8 head on the block that's in your car already). I'm pretty sure that will work. good luck.
WalkingKenshin
Mar 2, 2004 11:49 PM
