hit a curb! help me out
what the worse that can happen to my car?
theres all this **** leaking out on the front right tire
i know its got to the suspensionarms that are bent
the brake lines
axles
what else
i know im gonna get flames 4 this but i just need some help
the brake lines
axles
what else
You're F#@&*$.
Just had the same thing happen to my ride. I thought that the damage couldn't have been more than knocking everything out of alignment, but $2K later my car is back to normal.
if you have stuff leaking fluid it can only mean brake fluid, blown strut, or grease from your CV joint. Get it to a shop so they can put it on a lift and see what hidden damage there is.
I hit a curb going 35-45 MPH (not having ABS sucks) on a rainy day...Only thing happen was that I couldn't get my car aligned because it was far from the factory specs...then the body shop fiqured it was the lower arm bar...so I got it fix for around 2 bills...Now the car drives straight.
i slammed into a curb doing 55, had to replace rear crossbeam, knuckle, wheel, caliper, lower and upper control arms, and radius rod. Really not good.
Project_ED8
Nov 23, 2003 11:39 AM
