FastBrakes
Old Feb 9, 2003 | 10:10 PM
.Ryan's Avatar
Don't Trust Anyone
Default FastBrakes
Between a SW388 with +35 and +45 offset which is better for fitting the wilwood fastbrakes behind? I will need wheel spacers correct? Is that good or bad? Will I also need extended wheel studs? Be running on 205-50-15 Azenis also.
Old Feb 9, 2003 | 11:05 PM
spoon_ek9's Avatar
Default Re: FastBrakes (SpoonSportsEH2)
kosei K1 with 38 offset will fit for sure................
also sww388 only have 15 X 6.5. i think its better to run 15 X 7 rim if you want to use azenis.
[Modified by spoon_ek9, 8:06 AM 2/10/2003]
Old Feb 9, 2003 | 11:10 PM
STEALTHMODECOUPE's Avatar
Default Re: FastBrakes (spoon_ek9)
i agree
adaM
Old Feb 9, 2003 | 11:14 PM
.Ryan's Avatar
Don't Trust Anyone
will 15x7 TE37 clear the Fastbrakes?
Old Feb 9, 2003 | 11:17 PM
spoon_ek9's Avatar
i am sure 35 offset(TE37) will clear the brake, but i dunno if you can clear your fender and 1/4 panel.
Old Feb 10, 2003 | 04:22 PM
.Ryan's Avatar
Don't Trust Anyone
So which size, 15x6.5 or 15x7?
Old Feb 10, 2003 | 04:26 PM
wHOAlly's Avatar
email brian, he has 2 differnt wilwood setups, the normal one, and one that is designed to clear 15" wheels.
Old Feb 10, 2003 | 07:44 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
15" te`s with 35mm are fine on my eg. I`m not running azenis though.
gSrTEG&91hatch
Apr 17, 2011 01:06 AM
vtec128
Suspension & Brakes
Oct 29, 2009 09:46 PM
nikolai.
11
Jan 23, 2008 01:11 PM
dj_seloe
16
Sep 24, 2003 06:58 AM
GQ 05YellowEVO8
Jan 22, 2002 11:53 AM
