Where Does My Coolant Go? / Lsvtec Problems
Old Feb 9, 2003 | 07:46 PM
Wong Wonder's Avatar
Default Where Does My Coolant Go? / Lsvtec Problems
Every few days I have to fill up my reservoir.Is coolant suppose to spill out of the radiator cap if I twist it when its hot? Could it be a faulty cap?
On some days I see a very fine white smoke coming from around the middle section of my block on the passenger side. Any ideas?
Old Feb 9, 2003 | 08:13 PM
nfn15037's Avatar
Default Re: Where Does My Coolant Go? / Lsvtec Problems (Wong Wonder)
Sounds like a headgasket issue. Colant is under extremely high pressure. It gets hotter than the boiling point of water, so it needs to be under pressure so it wont boil, when you de-pressureize the cooling system, the water all boils. Do not remove the rad. cap when hot!! You will burn the **** out of yourself!!
[Modified by nfn15037, 9:14 PM 2/9/2003]
Old Feb 11, 2003 | 11:44 AM
Default Re: Where Does My Coolant Go? / Lsvtec Problems (nfn15037)
headgasket? any other areas I should check out?
Old Feb 11, 2003 | 12:52 PM
nfn15037's Avatar
I mean, its gonna be pretty obvous if its anything else. There are only a few ways to loose coolant. Check the radiator for cracks as well as the hoses, if you dont find anything, chances are its the headgasket.
Old Feb 11, 2003 | 01:08 PM
MikeSarr_GSR's Avatar
if you aint leaking fluid... through your exhaust yO! change the headgasket pronto.
Old Feb 11, 2003 | 05:25 PM
Hondaaccordvtec's Avatar
Default Re: Where Does My Coolant Go? / Lsvtec Problems (MikeSarr_GSR)
REmove your Oil filler cap on your valve cover and look at the underside. If you see a white frothy build up (mechanics call it "peanut butter"). You have a BLOWN headgasket. This is where your coolant is going (mixing with your oil).
Old Feb 11, 2003 | 06:54 PM
91integraLSVTEC's Avatar
Default Re: Where Does My Coolant Go? / Lsvtec Problems (Hondaaccordvtec)
another way to check to see if your headgasket is holding pressure, start your car with the radiator cap off.. if coolant is shooting out off the radator its your headgasket.. if you recently just installed the headgasket then you have a soft spot on either the deck of the block or the head.. only way to fix that is to resurface the head and deck the block, any machine shop can do that.
gurlugotmilk
Honda S2000
Feb 23, 2009 08:26 AM
korean_teg
Sep 29, 2005 07:00 PM
mickey513
Dec 20, 2004 11:21 AM
mightyone
Nov 4, 2003 10:53 PM
satintegra
Jun 6, 2002 11:56 PM
